Monitoring F5 Load balancers
Re: Monitoring F5 Load balancers
Try changing line 50 in the plugin -
my($TIMEOUT) = 10; # snmp timeout seconds
to
my($TIMEOUT) = 60; # snmp timeout seconds
Then do not specify a -t value.
aap
Post by aap »
Unfortunately, this has not helped much. Still the same.
I have increased the retry interval to 5mins in a bid to delay a notification being sent out =even though the service shows as Critical on the console.
Will see if that helps.
You could also setup that service to have a notification delay so if the check returns to an OK state before the notification delay, that should work as well.
aap
Post by aap »
Please close this thread.
