How im can change Service Periods ??
almirf
Re: How im can change Service Periods ??
Post by almirf »
im set the time in service
The correct is the service or in the host?
Almir
tgriep wrote:From your screen capture, if you take the difference between the last check time and the next scheduled check, that would be the check_interval.
These are your values
Last Check time = 21-07-2016 13:28:02
Next Scheduled Check = 21-07-2016 13:34:00
The only thing can see wrong is that is is scheduled for 6 minutes and not 7 minutes that you want.
You may want to upgrade to a newer version of Nagios as there could be bugs in the scheduler that could cause the 1 minute discrepancy.
I don't understand your question, can you provide more detail?
Are you asking if the check_interval is different for host checks and service checks?
Yes they are, you can have different intervals between them and that is valid.
