Plugins Helps
kwhogster
Re: Plugins Helps
Post by kwhogster »
if I remove the .cfg then I am back to the original error.
I ran find / -name check_nrpe
see attached file
checknrpe.txt
find output
(77.52 KiB) Downloaded 374 times
Re: Plugins Helps
Post by Box293 »
Your output indicates that you do not have the check_nrpe plugin installed on your Nagios server.
In this guide you referenced:
http://xmodulo.com/nagios-remote-plugin ... linux.html
It was supposed to be installed with:
apt-get install nagios-nrpe-plugin
And should be installed here:
/usr/lib/nagios/plugins/check_nrpe
This guide also shows how to install check_nrpe from Source (it's down the bottom).
https://support.nagios.com/kb/article.php?id=515
kwhogster
Re: Plugins Helps
Post by kwhogster »
Ok I ran
Now I have check_nrpe in /usr/lib/Nagios/plugins the install placed it in there
I changed my commands.cfg to remove the .cfg
command_name check_nrpe
command_line /usr/lib/nagios/plugins/check_nrpe.cfg -H '$HOSTADDRESS$' -c '$ARG1$'
is now this
command_line /usr/lib/nagios/plugins/check_nrpe -H '$HOSTADDRESS$' -c '$ARG1$'
the ran this
/usr/local/nagios/bin/nagios -vv /usr/local/nagios/etc/nagios.cfg
All good
/etc/init.d/nagios reload
OK
service nagios restart
Checked the web interface
Now getting a warning not critical getting much closer this is the warning msg
No handler for command: check_disk_space
Thoughts
Re: Plugins Helps
Post by Box293 »
On your NRPE client look in the nrpe.cfg file.
Down the bottom of the file you'll see command examples. check_disk_space is most likely not defined.
kwhogster
Re: Plugins Helps
Post by kwhogster »
My nrpe.cfg which is in /usr/local/Nagios/etc/objects
# NRPE.CFG
# Defined Hosts and Services for the Ngios Plugins
# Define Plugin Hosts
# Define Plugin Services
host_name TGCS011
service_description Check Disk Usage
check_command check_nrpe!check_disk_space! -v -w 80 -c 90 -p C
check_interval 1
Re: Plugins Helps
Post by Box293 »
No, this file you showed us is from your Nagios server.
On the machine running the NRPE client there is a nrpe.cfg file which looks completely different.
kwhogster
Re: Plugins Helps
Post by kwhogster »
nrpe client??????
I do not have nrpe client installed on any windows computer.
I have nsclient ++ installed on all my windows computers
I thought NRPE could communicate with nsclient ++
is there something I need to do in the nsclinet.ini ????
Re: Plugins Helps
NRPE can be used through Linux, or also as part of the NSClient++ package on Windows.
Yes, you need to modify your nsclient.ini file to define the command and plugin to use for check_disk_space. Specifically, under this section (add it if you do not have it anywhere) -
Then, under that section, you need to define it (change check_disk_space.vbs to the plugin you're trying to execute on the windows machine - most plugins will tell you exactly how to define the command) -
check_disk_space=cscript.exe //nologo //T:30 scripts\\check_disk_space.vbs "$ARG1$" "$ARG2$" "$ARG3$"
(this is just an example)
Re: Plugins Helps
Post by Box293 »
If you're using NSClient++ then there's no need for any extra scripts, it has a built in module to do that. See examples here:
http://sites.box293.com/nagios/guides/c ... disk-usage
kwhogster
Re: Plugins Helps
Post by kwhogster »
I am running nsclient ++ 0.4.1.73
This is from the link you posted
NSClient++ 0.4.1
No additional configuration is required
Command:
check_nrpe -H 192.168.142.137 -t 30 -c CheckDriveSize -a ShowAll MinWarn=10G MinCrit=5G CheckAll perf-unit=G
Output:
OK: C:\: 11.5G, D:\: 90.4M|'C:\ %'=81%;83;91 'C:\'=11.51G;10;5;0;59 'D:\ %'=100%;49;74 'D:\'=0.08G;10;5;0;19.99
Do I create this command in the nrpe.cfg file?
I ran it on the server
root@TGCS017:/usr/lib/nagios/plugins# ./check_nrpe -H 10.2.8.30 -t 30 -c CheckDriveSize -a Showall MinWarn=10G MinCrit=5G checkall perf-unit=g
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
I ran this too
I (0,4,1,73 2012-12-17) seem to be doing fine...
I am attaching my nsclient.ini also
nsclient.ini
NSCLIENT++ INI File
(7.28 KiB) Downloaded 348 times
