NLS Backups not showing in Web UI Since upgrade to NLS 1.4.2
roddergreg
Re: NLS Backups not showing in Web UI Since upgrade to NLS 1
Post by roddergreg »
curl -XGET '127.0.0.1:9200/_snapshot/logserverbackups':
{"logserverbackups":{"type":"fs","settings":{"compress":"true","location":"/usr/
curl -XGET '127.0.0.1:9200/_snapshot/logserverbackups/_all':
{"error":"ElasticsearchParseException[Failed to derive xcontent from (offset=0, length=0): []]","status":400}
Was this the full output from the command?
I'm a bit concerned if so. It should show the full path, but it looks like yours is getting cutoff at /usr/ and not respecting the path you've set.
[root@localhost US]# curl -XGET '127.0.0.1:9200/_snapshot/logserverbacurl -XGET '127.0.0.1:9200/_snapshot/nls'
{"nls":{"type":"fs","settings":{"compress":"true","location":"/usr/local/nagioslogserver/logserverbackups"}}}
roddergreg
gcooper@wmsyslog1-prd # curl -XGET '127.0.0.1:9200/_snapshot/logserverbackups'
{"logserverbackups":{"type":"fs","settings":{"compress":"true","location":"/usr/local/nagioslogserver/logserverbackups"}}}gcooper@wmsyslog1-prd #
cooper@wmsyslog1-prd # curl -XGET '127.0.0.1:9200/_snapshot/logserverbackups/_all'
This is the full output.
Is submitting a ticket in an option for you? This might be better handled over a remote at this point.
roddergreg
I believe our support plan only covers planned maintenance (upgrades etc.) We do not have customer support in our contract agreement.
Post by mcapra »
It looks like one of your snapshots is corrupted. Not quite sure how that happened (this can result from a lack of disk space), but I think the best course of action is to clear out the repository completely. There doesn't exist an easy way to identify which individual snapshot is corrupted.
Before we fully commit to that, can you share the output of:
curator --dry-run delete snapshots --repository logserverbackups --all-snapshots
roddergreg
uid=44371(nagios) gid=100(users) groups=100(users),48(apache),1000(nagios)
[nagios@wmsyslog1-prd ~]$ curator --dry-run delete snapshots --repository logserverbackups --all-snapshots
2016-08-18 10:04:30,387 INFO Job starting: delete snapshots
2016-08-18 10:04:30,387 INFO DRY RUN MODE. No changes will be made.
2016-08-18 10:04:30,608 ERROR Unable to find all snapshots in repository: logserverbackups
2016-08-18 10:04:30,608 ERROR No snapshots found in Elasticsearch.
Post by mcapra »
Very strange behavior. Can you share the output of:
ls -al /usr/local/nagioslogserver/logserverbackups/
roddergreg
I deleted all the files in /usr/local/nagioslogserver/logserverbackups since you spoke of corruption. We have tape backups anyway. Can you post the default config file for eleasticsearch.yml? I think i might have changed this file when the problems started.
/usr/local/nagioslogserver/elasticsearch/config/elasticsearch.yaml.
Please add as attachment and I'll replace what i currently have in place.
Greg
Post by mcapra »
Here's my elasticsearch.yml, not sure if the yaml was a typo. Had to upload as txt due to forum restrictions; Make sure you change the extension!
