Windows 10 Explorer Serrvice
kwhogster
Re: Windows 10 Explorer Serrvice
Post by kwhogster »
good catch
NSClientServer = 1
Now all services are reporting as they where before the upgrade of the nsclient
Only problem is that EXPLORER is still not reporting correctly
I am logged on to my Windows 10 computer and it is reporting critical explorer is not running
Thoughts
kwhogster
Post by kwhogster »
box293
Thanks I will check that when I get home from work
kwhogster
Post by kwhogster »
Guys
Now it went to warning no data received from host
Thoughts
kwhogster
Post by kwhogster »
guys
keeps flickering between critical and warning still does not see explorer.
Command line
./check_nt -H 10.2.8.69 -p 12489 -v PROCSTATE -l Explorer.exe -s xxxxxxxxxxx
CRITICAL: Explorer.exe: not running
Strange one
Any ideas
Post by Box293 »
It's probably case sensitive.
Try explorer.exe
kwhogster
Post by kwhogster »
root@tgcs017:/usr/lib/nagios/plugins# ./check_nt -H 10.2.8.69 -p 12489 -v PROCSTATE -l explorer.exe -s xxxxxxxx
OK: all processes are ok.
This is strange from command line it is ok but not in Nagios gui
I just changes the entry in computer.cfg from Explorer.exe to explorer.exe
Lets see if that changes
Post by Box293 »
Why do you want to monitor explorer.exe?
It is only running when a user is logged onto the windows system.
kwhogster
Post by kwhogster »
It is good now
Changing the Explorer.exe to explorer.exe seems to fix explorer
Lets see what happens over the next day or so
I monitor explorer so I know my computer is still logged on
I will post later with results
Post by mcapra »
Let us know if there are any updates! If this method is not successful, there are other options for checking for logged-in users.
kwhogster
Post by kwhogster »
What are the other methods
It is has been working all week
This can be marked as resolved
Thanks every one
