Check_by_ssh issue
MarMottE
Re: Check_by_ssh issue
Post by MarMottE »
Box293 wrote:
tgriep wrote:I am thinking that the error is the printing of the message of the day or the banner when you login to the remote system.
Adding -E 1 to the check_by_ssh command will ignore the first line of output.
In my previous message page 1, I have put the command definition and there is already -E 1
The check_by_ssh
# 'ssh_disk' command definition
command_name ssh_disk
command_line /usr/local/nagios/libexec/check_by_ssh -i /home/nagios/.ssh/id_dsa -H '$HOSTADDRESS$' -E 1 -C "/usr/lib/nagios/plugins/check_disk -w $ARG1$ -c $ARG2$ -e -p '$ARG3$'"
It could also be the single quotes around the macros remove them and see if that works for you.
/usr/local/nagios/libexec/check_by_ssh -i /home/nagios/.ssh/id_dsa -H $HOSTADDRESS$ -E 1 -C "/usr/lib/nagios/plugins/check_disk -w $ARG1$ -c $ARG2$ -e -p $ARG3$"
MarMottE
Post by MarMottE »
No, the same ..
Can you login to the Nagios server as the nagios user and run the command like in the previous post, filling in the IP Address and arguments and post the output here?
MarMottE
Post by MarMottE »
tgriep wrote:Can you login to the Nagios server as the nagios user and run the command like in the previous post, filling in the IP Address and arguments and post the output here?
nagios@nagiosserver:/usr/local/nagios/libexec$ ./check_by_ssh -i /home/nagios/.ssh/id_dsa -H xxxxxx -E 1 -C "/usr/lib/nagios/plugins/check_disk -w 10 -c 20 -e -p /"
DISK OK| /=4453MB;12677;12667;0;12687
Could you please post your service definition for the one that's using this check_command and failing? The command definition looks good, as well as the fact it's working over the CLI.
MarMottE
Post by MarMottE »
rkennedy wrote:Could you please post your service definition for the one that's using this check_command and failing? The command definition looks good, as well as the fact it's working over the CLI.
host_name xxxxxxx,
service_description /
check_command ssh_disk!20%!10%!/
To rule out parsing and values getting lost in translation, could you create a new command definition and assign this to your service?
$USER1$/check_by_ssh -i /home/nagios/.ssh/id_dsa -H xxxxxx -E 1 -C "/usr/lib/nagios/plugins/check_disk -w 10 -c 20 -e -p /"
This isn't ideal, but it will at least help us to see what's going on. Let us know what the status is for the check when it comes back.
MarMottE
Post by MarMottE »
rkennedy wrote:To rule out parsing and values getting lost in translation, could you create a new command definition and assign this to your service?
command_name ssh_disk_test
command_line $USER1$/check_by_ssh -i /home/nagios/.ssh/id_dsa -H '$HOSTADDRESS$' -E 1 -C "/usr/lib/nagios/plugins/check_disk -w 10 -c 20 -e -p /"
host_name xxxxxx, xxxxxxx
service_description /_test
check_command ssh_disk_test
It's the same ... check goes down when the session is closed
/_test
Perform Extra Service Actions
CRITICAL 09-05-2016 11:26:18 0d 0h 3m 16s 3/3 (Return code of 255 is out of bounds)
It really sounds like the storage isn't persistent if that's the case. What type of firewall device is this?
