Error reloading configuration
Re: Error reloading configuration
Your configuration will keep failing as long as you have duplicate object definitions (in the CCM/database and in the static directory). I am pretty sure that you have "xi_host_firewall" defined in both, the DB, and in "/usr/local/nagios/etc/static/xitemplates.cfg". Delete duplicate entries, then verify the configuration via the "Write Config Files" tool.
cyient
Post by cyient »
lmiltchev wrote:Your configuration will keep failing as long as you have duplicate object definitions (in the CCM/database and in the static directory). I am pretty sure that you have "xi_host_firewall" defined in both, the DB, and in "/usr/local/nagios/etc/static/xitemplates.cfg". Delete duplicate entries, then verify the configuration via the "Write Config Files" tool.
Thank you very much !!
I have commented out each and every duplicate entry in "/usr/local/nagios/etc/static/xitemplates.cfg" file by verifying the configuration, at last succeeded.
Awesome! Are we good to mark this thread as resolved?
cyient
Post by cyient »
rkennedy wrote:Awesome! Are we good to mark this thread as resolved?
Sorry for the delayed response.
Please mark it as resolved.
