Sep 16 13:02:20 nexusfirewall nrpe[8411]: Connection from xxx.xxx.xxx.xxx port 44764
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Host address is in allowed_hosts
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Handling the connection...
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Host is asking for command 'check_nexus_listen' to be run...
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Running command: /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh -p 8070 -P tcp
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Command completed with return code 3 and output:
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Return Code: 3, Output: NRPE: Unable to read output
Sep 16 13:02:20 nexusfirewall nrpe[8411]: Connection from P[▒T▒#177 closed.Code: Select all
2>&1Code: Select all
[root@engmon ~]# /usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -c check_nexus_listen
sh: /usr/lib64/nagios/plugins/check_listen_tcp_udp.sh: /bin/sh: bad interpreter: Permission denied
