Hi
I was trying to send a private message, but I wasn't allowed. (Or maybe I am doing it not correctly I don't know, I am new to this forum). Anyhow I have attached the files that were requested. I hope it is what you need and hopefully you can make this message into a private one.
Mod Edit: Profile received and shared with team
Nagios XI - Google Maps Plugin
Re: Nagios XI - Google Maps Plugin
- Former Nagios Staff
@Pachinko
Did you get the Google API key as suggested?
Replace
<script type="text/javascript" src="https://maps.google.com/maps/api/js?sen ... "></script>
with
<script type="text/javascript" src="https://maps.google.com/maps/api/js?key ... "></script>
Replace
with
I got the API key and did what you asked. It took some time after the change but when I retried yesterday evening it worked.
I do have one question: is the use of the API key free? I now requested one with my personal Google account because he asked me to log in. In the future this would need to change to a company account but I want to make sure that there is no extra cost involved in using the API key.
Thank you already for the great support!
When you requested the API did it mention anything about limitations for the use of it? This question is probably answered best on their page since we do not have direct control of their API.
I had a look on their website and until 25 000 requests a day the use is free. So for our company that is no issue. Thank you for the support it works now
avandemore
Just be aware this is an AJAX driven metric so depending on usage and settings, 25,000 requests can be relatively easy to hit.
Previous Nagios employee
Ok thank you for the information. I will take it into consideration.
avandemore
No problem, are we okay to lock this thread?
Cannot speak for OP, but my problem has been resolved. I am ok with locking the thread.
@rh2832, please let us know if your issue is resolved. Thanks!
