grok whitespace strip not working
gsl_ops_practice
Re: grok whitespace strip not working
Post by gsl_ops_practice »
In the end I had to add the following for all the fields I need:
  mutate {
    convert => { "fieldname1" => "integer" }
    convert => { "fieldname2" => "integer" }
    convert => { "fieldname3" => "integer" }
    convert => { "fieldname4" => "integer" }
to the filter and then delete all the indexes.
Now I am able to get the values displayed over time in the histogram and create monitoring queries for NagiosXI as well.
Thank you for your support, please consider this issue resolved.
Alex
Post by mcapra »
gsl_ops_practice wrote: the histogram
Ah, makes sense. Histograms don't work so well with strings. Thanks for sharing your findings!
