Long apply configurations
WillemDH
Re: Long apply configurations
Post by WillemDH »
ls -la /dev/mapper/*
crw-rw---- 1 root root 10, 58 Nov 22 15:13 /dev/mapper/control
lrwxrwxrwx 1 root root      7 Nov 22 15:13 /dev/mapper/VolGroup00-LogVol00 -> ../dm-1
lrwxrwxrwx 1 root root      7 Nov 22 15:13 /dev/mapper/VolGroup00-LogVol01 -> ../dm-0
cat /proc/mounts
rootfs / rootfs rw 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
devtmpfs /dev devtmpfs rw,relatime,size=6082400k,nr_inodes=1520600,mode=755 0 0
devpts /dev/pts devpts rw,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /dev/shm tmpfs rw,relatime 0 0
/dev/mapper/VolGroup00-LogVol00 / ext4 rw,relatime,barrier=1,data=ordered 0 0
/proc/bus/usb /proc/bus/usb usbfs rw,relatime 0 0
/dev/sda1 /boot ext2 rw,relatime,errors=continue 0 0
none /proc/sys/fs/binfmt_misc binfmt_misc rw,relatime 0 0
sunrpc /var/lib/nfs/rpc_pipefs rpc_pipefs rw,relatime 0 0
svm03:/backups/SERVER /var/Digipolis/Backup nfs rw,nosuid,nodev,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.54.18.38,mountvers=3,mountport=635,mountproto=udp,local_lock=none,addr=10.54.18.38 0 0
svm04:/naf /mnt/naf nfs ro,nosuid,nodev,noexec,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.54.18.41,mountvers=3,mountport=635,mountproto=udp,local_lock=none,addr=10.54.18.41 0 0
nfsd /proc/fs/nfsd nfsd rw,relatime 0 0
tmpfs /var/nagiosramdisk tmpfs rw,relatime,size=1048576k 0 0
Nagios XI 5.8.1
https://outsideit.net
avandemore
Post by avandemore »
I can't tell where /dev/mapper/VolGroup00-LogVol01 is being used, is it the swap device?
# cat /proc/swaps
Previous Nagios employee
WillemDH
Post by WillemDH »
cat /proc/swaps
Filename                                Type            Size    Used    Priority
/dev/dm-0                               partition       6553596 82392   -1
Seem to be so yes.
free -m
             total       used       free     shared    buffers     cached
Mem:         11904       9911       1992         71        179       4440
-/+ buffers/cache:       5291       6612
Swap:         6399         80       6319
I hear you coming(and saw the recommendations in the other thread) => I'll see about upping the RAM to 32 GB and will post the new load results during apply.
Tx and grtz
Nagios XI 5.8.1
avandemore
Sounds good. As it stands right now for your systems max IOPS appear to be halved. As in, whatever is the backing store for VolGroup00-LogVol00 and VolGroup00-LogVol01 are the ultimately the same physical device. So in a a situation where IO and memory pressure occur simultaneously, performance would severely impacted. Enough RAM would at least allow VolGroup00-LogVol00 to utilize the full amount of IOPS the backing store is capable of.
WillemDH
Post by WillemDH »
Can you explain further what you mean with this statement?
Nagios XI 5.8.1
avandemore
Another way to say it, is in your data, dm-0 and dm-1 appear to be competing for IOPS.
WillemDH
Post by WillemDH »
Avandemore,
So the server has now 32 GB RAM. Performance in the Nagios XI gui is definitely better. But the performance of the apply configuration process is not better. I did several apply configurations and the problem where hosts and services who are ack'ed or in downtime are shown is still there.
here are my logs:
Linux 2.6.32-642.6.2.el6.x86_64 (nagios01) 	12/09/2016 	_x86_64_	(6 CPU)
12/09/2016 01:57:24 PM
avg-cpu:  %user   %nice %system %iowait  %steal   %idle
          76.76    0.00    6.52    0.00    0.00   16.72
Device:         rrqm/s   wrqm/s     r/s     w/s   rsec/s   wsec/s avgrq-sz avgqu-sz   await r_await w_await  svctm  %util
sda               0.00    10.00    0.00   24.00     0.00   272.00    11.33     0.03    1.04    0.00    1.04   0.75   1.80
dm-1              0.00     0.00    0.00   34.00     0.00   272.00     8.00     0.04    1.03    0.00    1.03   0.53   1.80
12/09/2016 01:57:25 PM
          44.80    0.00    4.36    0.00    0.00   50.84
sda               0.00     4.00    0.00    6.00     0.00    80.00    13.33     0.01    1.50    0.00    1.50   1.33   0.80
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.02    1.60    0.00    1.60   0.80   0.80
12/09/2016 01:57:26 PM
          55.95    0.00    5.53    0.67    0.00   37.86
sda               0.00 12221.00    0.00  157.00     0.00 99024.00   630.73     2.23   14.18    0.00   14.18   0.82  12.90
dm-1              0.00     0.00    0.00 12378.00     0.00 99024.00     8.00   245.00   19.79    0.00   19.79   0.01  12.90
12/09/2016 01:57:27 PM
          55.85    0.00    5.35    0.17    0.00   38.63
sda               0.00    23.00    0.00   25.00     0.00   384.00    15.36     0.03    1.12    0.00    1.12   0.92   2.30
dm-1              0.00     0.00    0.00   48.00     0.00   384.00     8.00     0.05    1.00    0.00    1.00   0.48   2.30
12/09/2016 01:57:28 PM
          29.82    0.00    3.85    0.00    0.00   66.33
sda               0.00    65.00    0.00   49.00     0.00   912.00    18.61     0.10    2.12    0.00    2.12   0.24   1.20
dm-1              0.00     0.00    0.00  114.00     0.00   912.00     8.00     0.25    2.23    0.00    2.23   0.11   1.20
12/09/2016 01:57:29 PM
          34.06    0.00    4.03    0.00    0.00   61.91
sda               0.00     2.00    0.00    4.00     0.00    48.00    12.00     0.00    1.00    0.00    1.00   0.75   0.30
dm-1              0.00     0.00    0.00    6.00     0.00    48.00     8.00     0.01    1.00    0.00    1.00   0.50   0.30
12/09/2016 01:57:30 PM
          31.99    0.00    4.19    0.17    0.00   63.65
sda               0.00     7.00    0.00    7.00     0.00   112.00    16.00     0.01    0.71    0.00    0.71   0.71   0.50
dm-1              0.00     0.00    0.00   14.00     0.00   112.00     8.00     0.01    0.86    0.00    0.86   0.36   0.50
12/09/2016 01:57:31 PM
          62.14    0.00    5.03    0.34    0.00   32.50
sda               0.00   265.00    0.00  245.00     0.00  4080.00    16.65     1.93    7.89    0.00    7.89   0.15   3.60
dm-1              0.00     0.00    0.00  510.00     0.00  4080.00     8.00     4.66    9.14    0.00    9.14   0.07   3.60
12/09/2016 01:57:32 PM
          33.84    0.00    4.86    0.17    0.00   61.14
sda               0.00     3.00    0.00    9.00     0.00    96.00    10.67     0.01    1.00    0.00    1.00   0.67   0.60
dm-1              0.00     0.00    0.00   12.00     0.00    96.00     8.00     0.01    1.00    0.00    1.00   0.50   0.60
12/09/2016 01:57:33 PM
          29.22    0.00    3.67    3.01    0.00   64.11
sda               0.00   108.00    0.00 2212.00     0.00 18560.00     8.39    28.18   12.74    0.00   12.74   0.10  21.70
dm-1              0.00     0.00    0.00 2320.00     0.00 18560.00     8.00    29.58   12.75    0.00   12.75   0.09  21.80
12/09/2016 01:57:34 PM
          36.96    0.00    5.35    0.67    0.00   57.02
sda               0.00   190.00   75.00  691.00   600.00  7024.00     9.95     1.71    2.20    0.57    2.38   0.80  61.30
dm-1              0.00     0.00   75.00  887.00   600.00  7096.00     8.00     2.28    2.33    0.56    2.48   0.64  61.40
12/09/2016 01:57:35 PM
          25.55    0.00    6.26    0.00    0.00   68.19
sda               0.00   175.00   12.00  159.00    96.00  2696.00    16.33     0.37    2.33    0.33    2.48   0.84  14.30
dm-1              0.00     0.00   12.00  328.00    96.00  2624.00     8.00     1.20    3.64    0.33    3.76   0.42  14.30
12/09/2016 01:57:36 PM
          41.48    0.00    6.75    1.85    0.00   49.92
sda               0.00 13696.00   61.00  137.00   488.00 109648.00   556.24     2.13   10.57    0.95   14.85   0.90  17.80
dm-1              0.00     0.00   62.00 13834.00   496.00 110672.00     8.00   240.82   17.04    0.95   17.11   0.01  17.70
12/09/2016 01:57:37 PM
          39.63    0.00    4.35    1.00    0.00   55.02
sda               0.00  7873.00   21.00  113.00   168.00 64904.00   485.61     1.01    7.75    1.14    8.97   0.72   9.60
dm-1              0.00     0.00   20.00 7985.00   160.00 63880.00     8.00   107.07   13.89    1.15   13.92   0.01   9.60
12/09/2016 01:57:38 PM
          25.80    0.00    5.70    5.03    0.00   63.48
sda               0.00  4971.00    6.00 3450.00    48.00 67368.00    19.51    48.33   13.98    4.83   14.00   0.12  42.10
dm-1              0.00     0.00    6.00 8421.00    48.00 67368.00     8.00   135.82   16.12    4.83   16.13   0.05  42.10
12/09/2016 01:57:39 PM
          34.90    0.00    8.72    0.17    0.00   56.21
sda               0.00     1.00    0.00    4.00     0.00    40.00    10.00     0.01    3.75    0.00    3.75   3.50   1.40
dm-1              0.00     0.00    0.00    5.00     0.00    40.00     8.00     0.02    4.80    0.00    4.80   2.80   1.40
12/09/2016 01:57:40 PM
          37.48    0.00   10.22    0.17    0.00   52.13
sda               0.00     4.00    0.00    6.00     0.00    80.00    13.33     0.01    1.00    0.00    1.00   0.83   0.50
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.01    1.00    0.00    1.00   0.50   0.50
12/09/2016 01:57:41 PM
          54.10    0.00   16.42    0.67    0.00   28.81
sda               0.00 12728.00    3.00  139.00    24.00 102936.00   725.07     2.14   15.06    5.33   15.27   0.66   9.40
dm-1              0.00     0.00    3.00 12867.00    24.00 102936.00     8.00   242.29   18.83    5.33   18.83   0.01   9.40
12/09/2016 01:57:42 PM
          42.28    0.00    6.38    0.00    0.00   51.34
sda               0.00    16.00    0.00    9.00     0.00   200.00    22.22     0.01    1.67    0.00    1.67   1.33   1.20
dm-1              0.00     0.00    0.00   25.00     0.00   200.00     8.00     0.06    2.36    0.00    2.36   0.48   1.20
12/09/2016 01:57:43 PM
          32.05    0.00    4.19    0.17    0.00   63.59
sda               0.00   300.00    0.00   53.00     0.00  2824.00    53.28     0.12    2.25    0.00    2.25   0.40   2.10
dm-1              0.00     0.00    0.00  353.00     0.00  2824.00     8.00     1.68    4.76    0.00    4.76   0.06   2.10
12/09/2016 01:57:44 PM
          24.46    0.00    3.35    0.00    0.00   72.19
sda               0.00     4.00    0.00    4.00     0.00    64.00    16.00     0.00    1.00    0.00    1.00   1.00   0.40
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    1.00    0.00    1.00   0.50   0.40
12/09/2016 01:57:45 PM
          20.07    0.00    4.35    0.00    0.00   75.59
sda               0.00     5.00    0.00    3.00     0.00    64.00    21.33     0.00    1.00    0.00    1.00   1.00   0.30
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    1.00    0.00    1.00   0.38   0.30
12/09/2016 01:57:46 PM
          42.91    0.00    5.41    0.68    0.00   51.01
sda               0.00  3304.00    0.00  168.00     0.00 27776.00   165.33     1.78   10.61    0.00   10.61   0.45   7.50
dm-1              0.00     0.00    0.00 3472.00     0.00 27776.00     8.00    55.57   16.01    0.00   16.01   0.02   7.50
12/09/2016 01:57:47 PM
          35.79    0.00    4.52    0.17    0.00   59.53
sda               0.00     6.00    0.00   16.00     0.00   176.00    11.00     0.02    1.06    0.00    1.06   0.88   1.40
dm-1              0.00     0.00    0.00   22.00     0.00   176.00     8.00     0.03    1.18    0.00    1.18   0.64   1.40
12/09/2016 01:57:48 PM
          38.26    0.00    5.03    0.00    0.00   56.71
sda               0.00   766.00    0.00   58.00     0.00  6592.00   113.66     0.25    4.22    0.00    4.22   0.55   3.20
dm-1              0.00     0.00    0.00  824.00     0.00  6592.00     8.00     5.17    6.28    0.00    6.28   0.04   3.20
12/09/2016 01:57:49 PM
          34.34    0.00    4.36    0.17    0.00   61.14
sda               0.00     7.00    0.00   11.00     0.00   144.00    13.09     0.01    1.09    0.00    1.09   0.91   1.00
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.11    0.00    1.11   0.56   1.00
12/09/2016 01:57:50 PM
          53.52    0.00    8.05    1.34    0.00   37.08
sda               0.00  7134.00   81.00  538.00   648.00 61376.00   100.20     2.71    4.38    0.54    4.96   0.70  43.40
dm-1              0.00     0.00   81.00 7672.00   648.00 61376.00     8.00   141.80   18.29    0.57   18.48   0.06  43.40
12/09/2016 01:57:51 PM
          40.77    0.00    5.70    0.17    0.00   53.36
sda               0.00    10.00    0.00   18.00     0.00   224.00    12.44     0.02    1.00    0.00    1.00   0.78   1.40
dm-1              0.00     0.00    0.00   28.00     0.00   224.00     8.00     0.03    0.96    0.00    0.96   0.50   1.40
12/09/2016 01:57:52 PM
          45.73    0.00    5.03    0.17    0.00   49.08
sda               0.00    12.00    0.00   14.00     0.00   208.00    14.86     0.02    1.29    0.00    1.29   1.21   1.70
dm-1              0.00     0.00    0.00   26.00     0.00   208.00     8.00     0.03    1.27    0.00    1.27   0.65   1.70
12/09/2016 01:57:53 PM
          56.28    0.00    5.36    0.50    0.00   37.86
sda               0.00   129.00    0.00  515.00     0.00  5112.00     9.93     7.00   11.45    0.00   11.45   0.14   7.10
dm-1              0.00     0.00    0.00  797.00     0.00  6376.00     8.00     8.24    8.86    0.00    8.86   0.09   7.20
12/09/2016 01:57:54 PM
          44.54    0.00    9.08   12.27    0.00   34.12
sda               0.00   665.00    0.00 9101.00     0.00 78072.00     8.58   142.41   15.64    0.00   15.64   0.11 100.00
dm-1              0.00     0.00    0.00 9746.00     0.00 77968.00     8.00   153.26   15.71    0.00   15.71   0.10 100.00
12/09/2016 01:57:55 PM
          35.74    0.00    8.22   15.27    0.00   40.77
sda               0.00  6947.00    0.00 3732.00     0.00 85544.00    22.92   139.37   37.66    0.00   37.66   0.26  98.80
dm-1              0.00     0.00    0.00 10548.00     0.00 84384.00     8.00   372.05   35.39    0.00   35.39   0.09  98.80
12/09/2016 01:57:56 PM
          38.63    0.00    6.02    0.17    0.00   55.18
sda               0.00     6.00    0.00   10.00     0.00   128.00    12.80     0.01    1.20    0.00    1.20   1.00   1.00
dm-1              0.00     0.00    0.00   16.00     0.00   128.00     8.00     0.02    1.19    0.00    1.19   0.62   1.00
12/09/2016 01:57:57 PM
          36.01    0.00    4.69    0.00    0.00   59.30
sda               0.00     6.00    0.00   12.00     0.00   144.00    12.00     0.01    0.92    0.00    0.92   0.67   0.80
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    0.89    0.00    0.89   0.44   0.80
12/09/2016 01:57:58 PM
          43.48    0.00    6.52    0.17    0.00   49.83
sda               0.00     8.00    0.00   18.00     0.00   208.00    11.56     0.02    1.11    0.00    1.11   0.83   1.50
dm-1              0.00     0.00    0.00   26.00     0.00   208.00     8.00     0.03    1.12    0.00    1.12   0.58   1.50
12/09/2016 01:57:59 PM
          26.17    0.00    3.19    0.00    0.00   70.64
sda               0.00     3.00    0.00    7.00     0.00    80.00    11.43     0.01    1.43    0.00    1.43   1.14   0.80
12/09/2016 01:58:00 PM
          49.16    0.00    7.53    1.51    0.00   41.81
sda               0.00  7100.00    1.00  114.00     8.00 57712.00   501.91     1.39   12.12   17.00   12.08   0.81   9.30
dm-1              0.00     0.00    1.00 7214.00     8.00 57712.00     8.00   154.57   21.42   17.00   21.42   0.01   9.30
12/09/2016 01:58:01 PM
          62.71    0.00    8.03    0.33    0.00   28.93
sda               0.00    15.00    0.00   29.00     0.00   352.00    12.14     0.04    1.21    0.00    1.21   0.86   2.50
dm-1              0.00     0.00    0.00   44.00     0.00   352.00     8.00     0.05    1.11    0.00    1.11   0.57   2.50
12/09/2016 01:58:02 PM
          55.52    0.00   13.04    0.17    0.00   31.27
sda               0.00   302.00    0.00   44.00     0.00  2768.00    62.91     0.07    1.68    0.00    1.68   1.34   5.90
dm-1              0.00     0.00    0.00  346.00     0.00  2768.00     8.00     1.28    3.69    0.00    3.69   0.17   5.90
12/09/2016 01:58:03 PM
          46.89    0.00    6.55    0.00    0.00   46.55
sda               0.00    10.00    0.00   18.00     0.00   224.00    12.44     0.06    3.11    0.00    3.11   2.89   5.20
dm-1              0.00     0.00    0.00   28.00     0.00   224.00     8.00     0.07    2.50    0.00    2.50   1.86   5.20
12/09/2016 01:58:04 PM
          34.51    0.00    5.53    0.17    0.00   59.80
sda               0.00     8.00    0.00   14.00     0.00   176.00    12.57     0.02    1.43    0.00    1.43   1.00   1.40
dm-1              0.00     0.00    0.00   22.00     0.00   176.00     8.00     0.03    1.27    0.00    1.27   0.64   1.40
12/09/2016 01:58:05 PM
          52.19    0.00    8.42    1.35    0.00   38.05
sda               0.00   150.00   60.00  655.00   480.00  6448.00     9.69     2.38    3.32    0.62    3.57   0.64  46.10
dm-1              0.00     0.00   60.00  809.00   480.00  6472.00     8.00     2.93    3.36    0.62    3.57   0.53  46.20
12/09/2016 01:58:06 PM
          38.32    0.00    6.89    0.17    0.00   54.62
sda               0.00    52.00   16.00  169.00   128.00  1768.00    10.25     0.50    2.72    0.44    2.93   0.83  15.40
dm-1              0.00     0.00   16.00  218.00   128.00  1744.00     8.00     0.70    2.98    0.38    3.17   0.65  15.30
12/09/2016 01:58:07 PM
          46.45    0.00    7.26    0.34    0.00   45.95
sda               0.00  3879.00    0.00   89.00     0.00 31752.00   356.76     1.06   11.90    0.00   11.90   0.54   4.80
dm-1              0.00     0.00    0.00 3969.00     0.00 31752.00     8.00    79.12   19.94    0.00   19.94   0.01   4.80
12/09/2016 01:58:08 PM
          47.48    0.00    7.05    1.51    0.00   43.96
sda               0.00    80.00    0.00   36.00     0.00   928.00    25.78     0.14    3.81    0.00    3.81   3.58  12.90
dm-1              0.00     0.00    0.00  116.00     0.00   928.00     8.00     0.55    4.77    0.00    4.77   1.11  12.90
12/09/2016 01:58:09 PM
          32.38    0.00    5.06    0.00    0.00   62.56
sda               0.00     8.00    0.00    6.00     0.00   112.00    18.67     0.01    1.00    0.00    1.00   1.00   0.60
dm-1              0.00     0.00    0.00   14.00     0.00   112.00     8.00     0.01    1.00    0.00    1.00   0.43   0.60
12/09/2016 01:58:10 PM
          28.62    0.00    6.73    0.51    0.00   64.14
sda               0.00  9047.00    0.00  191.00     0.00 73928.00   387.06     1.98   10.36    0.00   10.36   0.32   6.10
dm-1              0.00     0.00    0.00 9241.00     0.00 73928.00     8.00   148.26   16.04    0.00   16.04   0.01   6.10
12/09/2016 01:58:11 PM
          65.83    0.00    7.04    0.17    0.00   26.97
sda               0.00    18.00    0.00   32.00     0.00   400.00    12.50     0.04    1.19    0.00    1.19   0.91   2.90
dm-1              0.00     0.00    0.00   50.00     0.00   400.00     8.00     0.06    1.18    0.00    1.18   0.60   3.00
12/09/2016 01:58:12 PM
          27.87    0.00    5.91    0.17    0.00   66.05
sda               0.00     9.00    0.00   11.00     0.00   160.00    14.55     0.01    1.09    0.00    1.09   1.00   1.10
dm-1              0.00     0.00    0.00   20.00     0.00   160.00     8.00     0.02    1.10    0.00    1.10   0.55   1.10
12/09/2016 01:58:13 PM
          39.36    0.00    6.03    0.00    0.00   54.61
sda               0.00     6.00    0.00   12.00     0.00   144.00    12.00     0.01    1.08    0.00    1.08   0.83   1.00
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.06    0.00    1.06   0.56   1.00
12/09/2016 01:58:14 PM
          29.97    0.00    5.56    0.17    0.00   64.31
sda               0.00    11.00    0.00   13.00     0.00   192.00    14.77     0.01    0.85    0.00    0.85   0.69   0.90
dm-1              0.00     0.00    0.00   24.00     0.00   192.00     8.00     0.02    0.83    0.00    0.83   0.38   0.90
12/09/2016 01:58:15 PM
          27.99    0.00    5.73    0.17    0.00   66.10
sda               0.00   596.00    0.00   41.00     0.00  5096.00   124.29     0.20    4.76    0.00    4.76   0.51   2.10
dm-1              0.00     0.00    0.00  637.00     0.00  5096.00     8.00     4.20    6.59    0.00    6.59   0.03   2.10
12/09/2016 01:58:16 PM
          49.58    0.00    6.53    0.00    0.00   43.89
sda               0.00     7.00    0.00   17.00     0.00   192.00    11.29     0.02    0.94    0.00    0.94   0.71   1.20
dm-1              0.00     0.00    0.00   24.00     0.00   192.00     8.00     0.02    0.96    0.00    0.96   0.50   1.20
12/09/2016 01:58:17 PM
          34.46    0.00    5.57    0.00    0.00   59.97
sda               0.00     8.00    0.00   16.00     0.00   192.00    12.00     0.02    1.19    0.00    1.19   0.94   1.50
dm-1              0.00     0.00    0.00   24.00     0.00   192.00     8.00     0.03    1.25    0.00    1.25   0.62   1.50
12/09/2016 01:58:18 PM
          46.41    0.00    7.35    0.17    0.00   46.08
sda               0.00    11.00    0.00   13.00     0.00   192.00    14.77     0.01    0.38    0.00    0.38   0.38   0.50
dm-1              0.00     0.00    0.00   24.00     0.00   192.00     8.00     0.01    0.50    0.00    0.50   0.21   0.50
12/09/2016 01:58:19 PM
          32.32    0.00    5.56    0.00    0.00   62.12
sda               0.00     7.00    0.00   11.00     0.00   144.00    13.09     0.01    1.27    0.00    1.27   1.09   1.20
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.28    0.00    1.28   0.67   1.20
12/09/2016 01:58:20 PM
          23.74    0.00    5.22    0.67    0.00   70.37
sda               0.00  7168.00    0.00  108.00     0.00 58208.00   538.96     1.39   12.86    0.00   12.86   0.54   5.80
dm-1              0.00     0.00    0.00 7276.00     0.00 58208.00     8.00   154.85   21.28    0.00   21.28   0.01   5.80
12/09/2016 01:58:21 PM
          58.05    0.00    8.05    1.17    0.00   32.72
sda               0.00   142.00  113.00  561.00   904.00  5624.00     9.69     1.73    2.56    0.78    2.92   0.82  55.00
dm-1              0.00     0.00  113.00  703.00   904.00  5624.00     8.00     2.15    2.63    0.78    2.93   0.67  55.00
12/09/2016 01:58:22 PM
          48.31    0.00    7.09    0.51    0.00   44.09
sda               0.00    16.00    0.00   18.00     0.00   264.00    14.67     0.11    1.06    0.00    1.06   3.94   7.10
dm-1              0.00     0.00    0.00   36.00     0.00   288.00     8.00     0.18    0.94    0.00    0.94   1.97   7.10
12/09/2016 01:58:23 PM
          36.82    0.00    7.94    0.51    0.00   54.73
sda               0.00    41.00    0.00   27.00     0.00   552.00    20.44     0.12    7.89    0.00    7.89   2.67   7.20
dm-1              0.00     0.00    0.00   66.00     0.00   528.00     8.00     0.31    6.94    0.00    6.94   1.11   7.30
12/09/2016 01:58:24 PM
          29.46    0.00    5.39    0.00    0.00   65.15
12/09/2016 01:58:25 PM
          32.44    0.00    5.88    0.34    0.00   61.34
sda               0.00  1638.00    0.00  124.00     0.00 14096.00   113.68     0.78    6.32    0.00    6.32   0.35   4.30
dm-1              0.00     0.00    0.00 1762.00     0.00 14096.00     8.00    21.02   11.93    0.00   11.93   0.02   4.30
12/09/2016 01:58:26 PM
          35.53    0.00    5.75    0.00    0.00   58.71
sda               0.00     5.94    0.00    9.90     0.00   126.73    12.80     0.01    0.80    0.00    0.80   0.70   0.69
dm-1              0.00     0.00    0.00   15.84     0.00   126.73     8.00     0.01    0.88    0.00    0.88   0.44   0.69
12/09/2016 01:58:27 PM
          36.30    0.00    5.88    0.17    0.00   57.65
sda               0.00     5.00    0.00   13.00     0.00   144.00    11.08     0.01    0.77    0.00    0.77   0.46   0.60
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.01    0.83    0.00    0.83   0.39   0.70
12/09/2016 01:58:28 PM
          18.41    0.00    4.90    0.00    0.00   76.69
sda               0.00     4.00    0.00    4.00     0.00    64.00    16.00     0.01    1.50    0.00    1.50   1.50   0.60
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    1.50    0.00    1.50   0.75   0.60
12/09/2016 01:58:29 PM
          23.06    0.00    4.88    0.00    0.00   72.05
sda               0.00     3.00    0.00    5.00     0.00    64.00    12.80     0.00    0.80    0.00    0.80   0.80   0.40
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    0.88    0.00    0.88   0.50   0.40
12/09/2016 01:58:30 PM
          25.67    0.00    6.54    0.84    0.00   66.95
sda               0.00  7224.00    0.00  458.00     0.00 60832.00   132.82     6.34   12.02    0.00   12.02   0.20   9.00
dm-1              0.00     0.00    0.00 7891.00     0.00 63128.00     8.00   148.37   18.63    0.00   18.63   0.01   9.00
12/09/2016 01:58:31 PM
          53.38    0.00    6.08    0.68    0.00   39.86
sda               0.00  1168.00    0.00  970.00     0.00 17728.00    18.28    12.83   14.08    0.00   14.08   0.12  11.50
dm-1              0.00     0.00    0.00 1929.00     0.00 15432.00     8.00    30.07   16.31    0.00   16.31   0.06  11.50
12/09/2016 01:58:32 PM
          37.19    0.00    6.87    0.17    0.00   55.78
sda               0.00    12.00    0.00   24.00     0.00   288.00    12.00     0.02    0.92    0.00    0.92   0.75   1.80
dm-1              0.00     0.00    0.00   36.00     0.00   288.00     8.00     0.04    0.97    0.00    0.97   0.50   1.80
12/09/2016 01:58:33 PM
          40.54    0.00    6.03    0.67    0.00   52.76
sda               0.00    10.00    0.00   18.00     0.00   224.00    12.44     0.08    4.61    0.00    4.61   4.39   7.90
dm-1              0.00     0.00    0.00   28.00     0.00   224.00     8.00     0.16    5.61    0.00    5.61   2.82   7.90
12/09/2016 01:58:34 PM
          21.51    0.00    5.55    0.00    0.00   72.94
sda               0.00     2.00    0.00    2.00     0.00    32.00    16.00     0.00    1.50    0.00    1.50   1.50   0.30
dm-1              0.00     0.00    0.00    4.00     0.00    32.00     8.00     0.01    1.50    0.00    1.50   0.75   0.30
12/09/2016 01:58:35 PM
          33.05    0.00    5.56    0.17    0.00   61.21
sda               0.00   871.00    0.00   29.00     0.00  7200.00   248.28     0.10    3.38    0.00    3.38   0.79   2.30
dm-1              0.00     0.00    0.00  900.00     0.00  7200.00     8.00     5.32    5.91    0.00    5.91   0.03   2.30
12/09/2016 01:58:36 PM
          34.79    0.00    6.89   15.13    0.00   43.19
sda               0.00   143.00    0.00 1669.00     0.00 14472.00     8.67   133.01   60.12    0.00   60.12   0.55  91.70
dm-1              0.00     0.00    2.00 1968.00    16.00 15744.00     8.00   140.68   54.38    0.00   54.44   0.47  91.70
12/09/2016 01:58:37 PM
          33.11    0.00   10.87   16.13    0.00   39.90
sda               0.00   349.00   51.00 3909.00   408.00 34032.00     8.70   115.45   37.40   11.06   37.75   0.25  97.70
dm-1              0.00     0.00   50.00 4108.00   400.00 32864.00     8.00   124.51   38.00   11.28   38.32   0.23  97.70
12/09/2016 01:58:38 PM
          48.47    0.00    9.49    0.68    0.00   41.36
sda               0.00   112.00   34.00  370.00   272.00  3912.00    10.36     0.93    2.36    0.47    2.54   0.89  35.90
dm-1              0.00     0.00   33.00  476.00   264.00  3808.00     8.00     1.90    3.83    0.48    4.07   0.71  35.90
12/09/2016 01:58:39 PM
          38.82    0.00    8.40    0.50    0.00   52.27
sda               0.00     8.00    0.00   15.00     0.00   184.00    12.27     0.07    4.33    0.00    4.33   4.00   6.00
dm-1              0.00     0.00    0.00   23.00     0.00   184.00     8.00     0.08    3.43    0.00    3.43   2.61   6.00
12/09/2016 01:58:40 PM
          27.99    0.00    5.90    0.67    0.00   65.43
sda               0.00  9003.00    0.00  128.00     0.00 73048.00   570.69     1.31   10.27    0.00   10.27   0.52   6.70
dm-1              0.00     0.00    0.00 9131.00     0.00 73048.00     8.00   135.00   14.78    0.00   14.78   0.01   6.70
12/09/2016 01:58:41 PM
          65.83    0.00    6.87    0.17    0.00   27.14
sda               0.00    18.00    0.00   28.00     0.00   368.00    13.14     0.03    1.14    0.00    1.14   0.96   2.70
dm-1              0.00     0.00    0.00   46.00     0.00   368.00     8.00     0.06    1.20    0.00    1.20   0.61   2.80
12/09/2016 01:58:42 PM
          28.24    0.00    6.55    0.17    0.00   65.04
sda               0.00  1083.00    0.00   80.00     0.00  9312.00   116.40     0.29    3.65    0.00    3.65   0.28   2.20
dm-1              0.00     0.00    0.00 1164.00     0.00  9312.00     8.00     6.22    5.34    0.00    5.34   0.02   2.20
12/09/2016 01:58:43 PM
          44.30    0.00    7.89    0.17    0.00   47.65
sda               0.00    13.00    0.00   28.00     0.00   328.00    11.71     0.04    1.32    0.00    1.32   1.00   2.80
dm-1              0.00     0.00    0.00   41.00     0.00   328.00     8.00     0.05    1.27    0.00    1.27   0.68   2.80
12/09/2016 01:58:44 PM
          28.76    0.00    4.18    0.17    0.00   66.89
sda               0.00     8.00    0.00   10.00     0.00   144.00    14.40     0.01    1.30    0.00    1.30   1.10   1.10
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.28    0.00    1.28   0.61   1.10
12/09/2016 01:58:45 PM
          39.09    0.00    5.37    0.17    0.00   55.37
sda               0.00    67.00    0.00   19.00     0.00   688.00    36.21     0.02    1.05    0.00    1.05   0.79   1.50
dm-1              0.00     0.00    0.00   86.00     0.00   688.00     8.00     0.21    2.43    0.00    2.43   0.17   1.50
12/09/2016 01:58:46 PM
          32.89    0.00    4.36    0.17    0.00   62.58
sda               0.00     8.00    0.00    8.00     0.00   128.00    16.00     0.03    3.12    0.00    3.12   3.12   2.50
dm-1              0.00     0.00    0.00   16.00     0.00   128.00     8.00     0.05    3.12    0.00    3.12   1.56   2.50
12/09/2016 01:58:47 PM
          42.95    0.00    5.03    0.50    0.00   51.51
sda               0.00    11.00    0.00   27.00     0.00   304.00    11.26     0.07    2.70    0.00    2.70   1.89   5.10
dm-1              0.00     0.00    0.00   38.00     0.00   304.00     8.00     0.11    2.92    0.00    2.92   1.34   5.10
12/09/2016 01:58:48 PM
          35.91    0.00    5.70    0.17    0.00   58.22
sda               0.00    12.00    0.00   13.00     0.00   200.00    15.38     0.02    1.38    0.00    1.38   1.31   1.70
dm-1              0.00     0.00    0.00   25.00     0.00   200.00     8.00     0.03    1.36    0.00    1.36   0.68   1.70
12/09/2016 01:58:49 PM
          28.81    0.00    5.70    0.00    0.00   65.49
sda               0.00     3.00    0.00    5.00     0.00    64.00    12.80     0.01    1.00    0.00    1.00   0.80   0.40
12/09/2016 01:58:50 PM
          41.85    0.00    5.88    0.50    0.00   51.76
sda               0.00  7035.00    0.00   86.00     0.00 56968.00   662.42     1.09   12.70    0.00   12.70   0.67   5.80
dm-1              0.00     0.00    0.00 7121.00     0.00 56968.00     8.00   127.29   17.88    0.00   17.88   0.01   5.80
12/09/2016 01:58:51 PM
          51.09    0.00    6.20    0.34    0.00   42.38
sda               0.00    11.00    0.00   23.00     0.00   272.00    11.83     0.03    1.35    0.00    1.35   1.00   2.30
dm-1              0.00     0.00    0.00   34.00     0.00   272.00     8.00     0.05    1.56    0.00    1.56   0.74   2.50
12/09/2016 01:58:52 PM
          41.62    0.00    4.40    2.71    0.00   51.27
sda               0.00   778.00    0.00 1600.00     0.00 18440.00    11.53    34.26   17.70    0.00   17.70   0.14  22.60
dm-1              0.00     0.00    0.00 2663.00     0.00 21304.00     8.00    42.82   12.92    0.00   12.92   0.08  22.60
12/09/2016 01:58:53 PM
          48.74    0.00    7.04    3.52    0.00   40.70
sda               0.00   445.00   84.00 2865.00   672.00 27064.00     9.41    35.92   14.20    0.79   14.59   0.26  77.50
dm-1              0.00     0.00   84.00 3025.00   672.00 24200.00     8.00    41.45   15.99    0.79   16.41   0.25  77.50
12/09/2016 01:58:54 PM
          23.32    0.00    3.36    0.00    0.00   73.32
sda               0.00     2.00    0.00    6.00     0.00    64.00    10.67     0.00    0.67    0.00    0.67   0.50   0.30
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    0.75    0.00    0.75   0.38   0.30
12/09/2016 01:58:55 PM
          30.08    0.00    4.87    0.00    0.00   65.04
sda               0.00     9.00    0.00    9.00     0.00   144.00    16.00     0.01    1.00    0.00    1.00   0.78   0.70
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.00    0.00    1.00   0.39   0.70
12/09/2016 01:58:56 PM
          35.80    0.00    4.20    0.17    0.00   59.83
sda               0.00     9.00    0.00    9.00     0.00   144.00    16.00     0.01    1.00    0.00    1.00   1.00   0.90
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.00    0.00    1.00   0.50   0.90
12/09/2016 01:58:57 PM
          38.99    0.00    5.55    0.34    0.00   55.13
sda               0.00  1791.00    0.00   45.00     0.00 14688.00   326.40     0.29    6.38    0.00    6.38   0.93   4.20
dm-1              0.00     0.00    0.00 1836.00     0.00 14688.00     8.00    25.02   13.63    0.00   13.63   0.02   4.20
12/09/2016 01:58:58 PM
          35.34    0.00    4.02    0.00    0.00   60.64
sda               0.00    39.00    0.00   61.00     0.00   800.00    13.11     0.20    3.26    0.00    3.26   0.34   2.10
dm-1              0.00     0.00    0.00  100.00     0.00   800.00     8.00     0.40    3.98    0.00    3.98   0.21   2.10
12/09/2016 01:58:59 PM
          20.71    0.00    4.04    0.00    0.00   75.25
sda               0.00     2.00    0.00    2.00     0.00    32.00    16.00     0.00    0.50    0.00    0.50   0.50   0.10
dm-1              0.00     0.00    0.00    4.00     0.00    32.00     8.00     0.00    0.50    0.00    0.50   0.25   0.10
12/09/2016 01:59:00 PM
          45.47    0.00    8.05    0.50    0.00   45.97
sda               0.00  7033.00    0.00   83.00     0.00 56928.00   685.88     1.07   12.87    0.00   12.87   0.67   5.60
dm-1              0.00     0.00    0.00 7116.00     0.00 56928.00     8.00   124.66   17.52    0.00   17.52   0.01   5.60
12/09/2016 01:59:01 PM
          64.65    0.00    6.06    0.51    0.00   28.79
sda               0.00    12.00    0.00   24.00     0.00   288.00    12.00     0.11    4.50    0.00    4.50   4.33  10.40
dm-1              0.00     0.00    0.00   36.00     0.00   288.00     8.00     0.20    5.44    0.00    5.44   2.89  10.40
12/09/2016 01:59:02 PM
          54.36    0.00   12.75    0.17    0.00   32.72
sda               0.00   128.00    0.00   67.00     0.00  1560.00    23.28     0.08    1.21    0.00    1.21   0.84   5.60
dm-1              0.00     0.00    0.00  195.00     0.00  1560.00     8.00     0.35    1.80    0.00    1.80   0.29   5.60
12/09/2016 01:59:03 PM
          27.52    0.00    5.70    0.17    0.00   66.61
sda               0.00    10.00    0.00   17.00     0.00   216.00    12.71     0.02    0.94    0.00    0.94   0.65   1.10
dm-1              0.00     0.00    0.00   27.00     0.00   216.00     8.00     0.03    1.00    0.00    1.00   0.41   1.10
12/09/2016 01:59:04 PM
          38.46    0.00    6.52    0.00    0.00   55.02
sda               0.00     9.00    0.00   17.00     0.00   208.00    12.24     0.01    0.82    0.00    0.82   0.59   1.00
dm-1              0.00     0.00    0.00   26.00     0.00   208.00     8.00     0.02    0.85    0.00    0.85   0.42   1.10
12/09/2016 01:59:05 PM
          27.85    0.00    5.03    0.17    0.00   66.95
12/09/2016 01:59:06 PM
          40.77    0.00    6.38    0.00    0.00   52.85
sda               0.00     7.00    0.00    9.00     0.00   128.00    14.22     0.01    0.67    0.00    0.67   0.67   0.60
dm-1              0.00     0.00    0.00   16.00     0.00   128.00     8.00     0.01    0.75    0.00    0.75   0.38   0.60
12/09/2016 01:59:07 PM
          37.08    0.00    4.87    0.17    0.00   57.89
sda               0.00   614.00    0.00   80.00     0.00  5552.00    69.40     0.43    5.36    0.00    5.36   0.28   2.20
dm-1              0.00     0.00    0.00  694.00     0.00  5552.00     8.00     5.70    8.22    0.00    8.22   0.03   2.20
12/09/2016 01:59:08 PM
          49.25    0.00    7.87    9.21    0.00   33.67
sda               0.00  2660.00   10.00 7559.00    80.00 81752.00    10.81   100.41   13.27    0.50   13.28   0.10  78.90
dm-1              0.00     0.00   10.00 10221.00    80.00 81768.00     8.00   142.46   13.92    0.50   13.94   0.08  78.90
12/09/2016 01:59:09 PM
          30.13    0.00    6.57    0.84    0.00   62.46
sda               0.00   232.00  101.00  695.00   808.00  7416.00    10.33     2.18    2.75    0.65    3.05   0.83  65.80
dm-1              0.00     0.00  101.00  925.00   808.00  7400.00     8.00     3.03    2.96    0.65    3.21   0.64  65.80
12/09/2016 01:59:10 PM
          34.00    0.00    6.53    0.67    0.00   58.79
sda               0.00  9086.00    0.00   98.00     0.00 73472.00   749.71     1.29   13.12    0.00   13.12   0.67   6.60
dm-1              0.00     0.00    0.00 9184.00     0.00 73472.00     8.00   151.72   16.52    0.00   16.52   0.01   6.60
12/09/2016 01:59:11 PM
          42.88    0.00    4.19    0.17    0.00   52.76
sda               0.00     8.00    0.00   18.00     0.00   208.00    11.56     0.01    0.83    0.00    0.83   0.61   1.10
12/09/2016 01:59:12 PM
          28.45    0.00    5.22    0.00    0.00   66.33
sda               0.00     6.00    0.00    9.00     0.00   120.00    13.33     0.02    1.78    0.00    1.78   1.56   1.40
dm-1              0.00     0.00    0.00   15.00     0.00   120.00     8.00     0.03    1.67    0.00    1.67   0.93   1.40
12/09/2016 01:59:13 PM
          28.02    0.00    3.86    0.00    0.00   68.12
sda               0.00     4.00    0.00   19.00     0.00   184.00     9.68     0.02    1.00    0.00    1.00   0.47   0.90
dm-1              0.00     0.00    0.00   23.00     0.00   184.00     8.00     0.02    1.00    0.00    1.00   0.39   0.90
12/09/2016 01:59:14 PM
          36.85    0.00    6.37    0.17    0.00   56.62
sda               0.00     7.00    0.00   15.00     0.00   176.00    11.73     0.01    0.87    0.00    0.87   0.67   1.00
dm-1              0.00     0.00    0.00   22.00     0.00   176.00     8.00     0.02    0.86    0.00    0.86   0.45   1.00
12/09/2016 01:59:15 PM
          23.95    0.00    4.02    0.17    0.00   71.86
sda               0.00  1693.00    0.00   76.00     0.00 14152.00   186.21     0.49    6.51    0.00    6.51   0.25   1.90
dm-1              0.00     0.00    0.00 1769.00     0.00 14152.00     8.00    15.75    8.91    0.00    8.91   0.01   1.90
12/09/2016 01:59:16 PM
          41.44    0.00    6.04    0.00    0.00   52.52
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.17    0.00    1.17   0.61   1.10
It seems like dm-0 (swap) has no activity anymore which should be a good thing. But as the problem is still there... I would like to say once more that imho this is a Nagios problem. I can see several types of solutions to tackle this problem. For example put a flag somewhere when the apply configuration is started. on a refresh of the open service problems and other views, check if the 'apply flag' is there and if so just show no hosts at all. At the final end of the apply process the flag should be rmeoved after which the hosts and services are showing again.
Could you please discuss this idea with a dev and see if this is doable. We rather have a long apply time with no hosts and services showing then a long apply time with all kinds of false positives.
Thanks.
Willem
Nagios XI 5.8.1
avandemore
I spoke with a dev yesterday on pretty much your proposed solution. We'll see were it goes.
I have created FR 10391 for this issue. You can inquire here or via ticket its status.
