Those are from namespaces(7) so likely a docker artifact.
# ls -l /proc/$$/ns Should print out some more detail.
check_disk v2.0.3 -x failed on centos 7 with docker mounts
avandemore
Re: check_disk v2.0.3 -x failed on centos 7 with docker moun
Previous Nagios employee
what is your docker version
mine is like following
Can you upgrade your test machine to same version to see if you have same issue ?
docker-engine-1.12.2-1.el7.centos.x86_64
avandemore
Can you provide more details on your Docker setup which would be generating these types of mounts? If I can reproduce this with a set of known steps, then a bug report would carry much more weight.
I agree the exact steps to reproduce the issue is good for filing a bug report.
I can't do much on the production docker VM, I will try to learn/config docker on a test centos 7 VM to reproduce the issue.
This till take me some time, please leave this post open.
avandemore
I'll leave it open, I don't know what version I used to test as the VM has been destroyed. It was the latest from official docs.
