You probably have not allowed 127.0.0.1 in your 'allowed_hosts' part. The difference is 10.146.1.100 has sspmutu's IP in it's allowed_hosts.katya wrote:Hi,
It very starnge but if i will run check_nrpe to mu nagios server (10.146.1.100) it will work
root@ssbpmutu:/usr/local/nagios/libexec# ./check_nrpe -H 10.146.1.100
NRPE v2.15
but if i will run to 127.0.0.1 it woul not. why? what is the difference?
root@ssbpmutu:/usr/local/nagios/libexec# ./check_nrpe -H 127.0.0.1
CHECK_NRPE: Error - Could not complete SSL handshake.
bin folder missing from /usr/local/nagios
Re: bin folder missing from /usr/local/nagios
127.0.0.1 is allowed in my nrpe.cfg it ssbpmutu server.
so this is not the issue, any other idea?
please see the evidnce:
/usr/local/nagios/etc
vi nrpe.cfg
allowed_hosts=127.0.0.1,10.146.1.100,10.146.1.35
vi nrpe.cfg
Login to you Solaris server and run the following.
If it returns the version of the NRPE Agent, that means that the NRPE agent did not get compiled with SSL enabled.
Try recompiling it again by following these instructions.
https://www.rootusers.com/compiling-nrp ... aris-11-2/
./check_nrpe -H 127.0.0.1 -nTry recompiling it again by following these instructions.
root@ssbpmutu:/usr/local/nagios/libexec# ./check_nrpe -H 127.0.0.1 -n
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
from /var/adm/messages
Nov 17 09:21:19 ssbpmutu su: [ID 366847 auth.notice] 'su root' succeeded for katya.ailarov on /dev/pts/2
Nov 17 09:21:42 ssbpmutu inetd[395]: [ID 317013 daemon.notice] nrpe[14787] from 127.0.0.1 53752
Nov 17 09:21:42 ssbpmutu nrpe[14787]: [ID 927837 mail.info] connect from localhost
Nov 17 09:21:42 ssbpmutu tcpd[14787]: [ID 826424 mail.error] error: cannot execute /application/nagios/bin/nrpe: No such file or directory
Nov 17 09:22:09 ssbpmutu sshd[14292]: [ID 800047 auth.info] Received disconnect from 10.146.1.100: 11: Terminating connection
Instead of taking the time to figure out why the old NRPE Agent didn't install on the Solaris server, try using the instructions below to install a newer version of the NRPE agent.
https://support.nagios.com/kb/article.php?id=515
i followed this procedure all the steps were done successfuly.
but when running check_nrpe got the following error:
CHECK_NRPE: Error - Could not connect to 127.0.0.1. Check system logs on 127.0.0.1
output from /var/adm/messages/:
Nov 22 09:39:11 ssbpmutu check_nrpe[21098]: [ID 130467 user.error] Error: Could not complete SSL handshake with 127.0.0.1: rc=0 SSL-error=5
It looks like the the SSL libraries are not installed on your server or that they did not get compiled in to the NRPE Agent.
Make sure that the SSL libraries are installed on your server and then run these commands to see if you can get SSL compiled in to the NRPE Agent and the check_nrpe command.
If it compiles without any errors, run this to install the agent
Then run this to restart the agent on the server
cd /tmp/nrpe-3.0/
./configure --enable-command-args –with-ssl=/usr/sfw/ –with-ssl-lib=/usr/sfw/lib/ –with-ssl-inc=/usr/sfw/include
gmake all
gmake install-initCode: Select all
svcadm disable nrpe
svcadm enable nrpeBe sure to check out our Knowledgebase for helpful articles and solutions!
root@ssbpmutu:/tmp/nrpe-3.0# ./configure --enable-command-args -with-ssl=/usr/sfw/ -with-ssl-lib=/usr/sfw/lib/ -with-ssl-inc=/usr/sfw/include
*** Configuration summary for nrpe nrpe-3.0 07-12-2016 ***:
General Options:
NRPE port: 5666
NRPE user: nagios
NRPE group: nagios
Nagios user: nagios
Nagios group: nagios
Review the options above for accuracy. If they look okay,
type 'make all' to compile the NRPE daemon and client
or type 'make' to get a list of make options.
You have mail in /var/mail/root
root@ssbpmutu:/tmp/nrpe-3.0# gmake all
cd ./src/; gmake
gmake[1]: Entering directory `/tmp/nrpe-3.0/src'
gcc -g -O2 -I/usr/sfw/include/openssl -DHAVE_CONFIG_H -I ../include -I ./../include -o nrpe ./nrpe.c ./utils.c ./acl.c -L/usr/sfw/lib/ -lssl -lcrypto -lnsl -lsocket
gcc -g -O2 -I/usr/sfw/include/openssl -DHAVE_CONFIG_H -I ../include -I ./../include -o check_nrpe ./check_nrpe.c ./utils.c -L/usr/sfw/lib/ -lssl -lcrypto -lnsl -lsocket
gmake[1]: Leaving directory `/tmp/nrpe-3.0/src'
*** Compile finished ***
You can now continue with the installation or upgrade process.
Read the PDF documentation (NRPE.pdf) for information on the next
steps you should take to complete the installation or upgrade.
You have new mail in /var/mail/root
root@ssbpmutu:/tmp/nrpe-3.0# gmake install-init
build-aux/install-sh -c -m 775 -g sys -d /var/svc/manifest/network/nagios
build-aux/install-sh -c -m 644 startup/solaris-init.xml /var/svc/manifest/network/nagios/nrpe.xml
svccfg import /var/svc/manifest/network/nagios/nrpe.xml
*** Run 'svcadm enable nrpe' to start it
root@ssbpmutu:/tmp/nrpe-3.0# svcadm disable nrpe
root@ssbpmutu:/tmp/nrpe-3.0# svcadm enable nrpe
root@ssbpmutu:/tmp/nrpe-3.0# cd /usr/local/nagios/libexec/
Agian not working
General Options:
NRPE port: 5666
NRPE user: nagios
NRPE group: nagios
Nagios user: nagios
cd ./src/; gmake
Agian not working
Try running this command on the Solaris server to see if it works.
What the -n does is to connect to the NRPE agent without SSL and if it works, then the agent did not get ssl compiled in to it and you will have to use the -n option in the check_nrpe command in the checks for that server.
./check_nrpe -H 127.0.0.1 -nBe sure to check out our Knowledgebase for helpful articles and solutions!
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
