Manage Users page SQL error
TBT
Re: Manage Users page SQL error
Post by TBT »
Yes, there was a failed upgrade in the past. Currently running 5.3.3, see attached upgrade log.
upgrade.log
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Thanks for the upgrade.log files, it didn't show any errors from before.
Lets add the missing tables to the postgress database manually but make a full backup of the server in case something doesn't work
Follow this procedure by logging in to the server as root.
cd /tmp
Make sure you delete the /tmp/nagiosxi/ directory and any old “tar.gz” files the exist. You can do this by running the following command:
rm -rf nagiosxi xi*.tar.gz
Next, download the latest stable release to the /tmp/ directory on the Nagios XI server. To download run the following command:
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
Unpack the updated tarball you just downloaded.
tar xzf xi-latest.tar.gz
Then run the following to add the missing tabled to the Postgress database.
psql nagiosxi nagiosxi -f /tmp/nagiosxi/nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql
After this, lets restart the nagios and apache processes by running
service httpd restart
service nagios restart
Login to the XI GUI and see if the error is gone now.
TBT
Post by TBT »
That did the trick. Thank you for your assistance.
Your welcome. If you don't have any other questions, shall I close the post as solved?
TBT
Post by TBT »
tgriep wrote:Your welcome. If you don't have any other questions, shall I close the post as solved?
Issue appears to be resolved.
