assign define hosts to specific users
baber
Re: assign define hosts to specific users
Post by baber »
tmcdonald wrote:
baber wrote:Yes i read that but previously said confused
Have you seen the documentation on how a host is defined?
https://assets.nagios.com/downloads/nag ... .html#host
You will need to add the contact name to the contacts field in your host definition if you want the contact to be able to see that host.
so thanks
My problem has been solved now with define contacti group babak can see specific hosts but now how can this user see specific service ?
BR
In the same way, except you define the contact in the service definition instead:
https://assets.nagios.com/downloads/nag ... ml#service
