403 error on openSUSE 42.2
CMOS
Re: 403 error on openSUSE 42.2
Post by CMOS »
I did restart Apache but no change in result.
Output of http - V
Server version: Apache/2.4.23 (Linux/SUSE)
Server built:   2016-09-13 13:41:45.000000000 +0000
Server's Module Magic Number: 20120211:61
Server loaded:  APR 1.5.1, APR-UTIL 1.5.3
Compiled using: APR 1.5.1, APR-UTIL 1.5.3
Architecture:   64-bit
Server MPM:     prefork
  threaded:     no
    forked:     yes (variable process count)
Server compiled with....
 -D APR_HAS_SENDFILE
 -D APR_HAS_MMAP
 -D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
 -D APR_USE_PROC_PTHREAD_SERIALIZE
 -D APR_USE_PTHREAD_SERIALIZE
 -D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
 -D APR_HAS_OTHER_CHILD
 -D AP_HAVE_RELIABLE_PIPED_LOGS
 -D DYNAMIC_MODULE_LIMIT=256
 -D HTTPD_ROOT="/srv/www"
 -D SUEXEC_BIN="/usr/sbin/suexec"
 -D DEFAULT_PIDLOG="/run/httpd.pid"
 -D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
 -D DEFAULT_ERRORLOG="/var/log/apache2/error_log"
 -D AP_TYPES_CONFIG_FILE="/etc/apache2/mime.types"
 -D SERVER_CONFIG_FILE="/etc/apache2/httpd.conf"
@mcapra was able to get it working with the following apache configurations (based off of yours). (see attached)
As we cannot control everything at play here with apache, I would take a look and diff what's in the zip to see if you're missing a setting somewhere, or if something has been done differently. It could even be a permission on the folder Nagios is trying to present to apache depending how things are setup to run in your environment.
apache2.zip
(49.91 KiB) Downloaded 335 times
CMOS
Post by CMOS »
I spun up a new VM and started over and Nagios appears to be working now. Not sure what the issue was/is but this solution works.
Thanks for trying and all the help.
Post by dwhitfield »
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
