Nagios Event Log NSCLIENT help
Re: Nagios Event Log NSCLIENT help
Can anyone on here figure this out please
I has to be a setting in Nagios or nsclient that I have not right I have tried different settings no luck
Tom
Tom
- Former Nagios Staff
As we suggested in the last tech post, did you try a different version of NSClient? .4.1 is old. .4.3 is the latest version in the .4 series, but they have moved on to .5.me@work55 wrote: I have tried different settings no luck
If you continue to have trouble with NSClient, you might try NCPA, which we did actually write: https://exchange.nagios.org//directory/ ... PA/details
I will try on 4.3.77
NCPA never used before would need some instructions on that setup or examples of that
Let us know how .4.3 goes.
As far as NCPA is concerned, https://assets.nagios.com/downloads/ncp ... g_NCPA.pdf should get you started, but if you have trouble with NCPA, you should open a new thread.
I put 4.3.77 on and now all the NRPE services I had working are not
They are all getting this
CHECK_NRPE: Error - Could not complete SSL handshake
NSCLIENT.INI not configured correctly my thoughts
.4.3.77 is a nightly build, per https://www.nsclient.org/download/0.4.3/ but probably you ran into the following
That said, please post your new nsclient.ini file.
from https://docs.nsclient.org/0.4.3/whatsnew/0.4.3.htmlIn 0.4.3 we will no longer support the rather insecure regular NRPE!
You can still enable support but you have to do so (in the installer or using the command line mode).
So keep a heads up when you run the installer so you wont miss it.
I am attaching the nsclient file that was created during the install
Also the one from 4.1.3
nsclient.ini- the 4.1.3 nsclient file
- (14.38 KiB) Downloaded 255 times
nsclient4.3.77.ini- New NSLCINET FILE
- (7.37 KiB) Downloaded 298 times
Please try changing the allowed hosts directive to an IP address instead of a DNS address:
Then restart the NSClient++ service and see if that works.
What does your nsclient.log show?
Are you just running this for testing?
I imported your config to mine, changed the DNS to my IP address and it worked properly so there may be something else going on.
allowed hosts = X.X.X.XWhat does your nsclient.log show?
/usr/local/nagios/libexec/check_nrpe -H X.X.X.XRe: Nagios Event Log NSCLIENT help
changed to ip address no change
from command
[root@anakin ~]# /usr/local/nagios/libexec/check_nrpe -H 132.238.5.25
CHECK_NRPE: Error - Could not complete SSL handshake.
[root@anakin ~]#
same error
from command
[root@anakin ~]#
same error
nsclient.log- NSCLIENT LOG
- (31.86 KiB) Downloaded 265 times
What version of check_nrpe are you running:
/usr/local/nagios/libexec/check_nrpe -V
