NRPE Socket timeout after 10 seconds
kwhogster
Re: NRPE Socket timeout after 10 seconds
Post by kwhogster »
I am still getting NRPE timeout some 60 some not but for most part 60 now
Question of the day is why does this happen in the first place.
Looking into escalation settings so I do not get bombed with emails
Thoughts?
update
Still getting issues with VMs I placed in the time period
CRITICAL 02-23-2017 21:16:23 0d 0h 5m 22s 1/3 (Service check timed out after 61.42 seconds)
Thoughts
When running the check_nrpe against a remote host and that remote host doesn't respond within the timeout period, it will timeout the plugin so it will not continue running the plugin on the server and fill up it's memory.
And it will give the socket timeout message.
Without getting all of the configuration files and the names of the hosts that are timing out, it will be difficult to troubleshoot.
kwhogster
Post by kwhogster »
Hello guys
This is all and internal network I am not monitoring any remote sites or hosts.
All monitored hosts are on the same subnet
It is just the VM machine that get this most of the time
Whether the system is local or remote doesn't matter, if it doesn't respond in time, it will timeout.
kwhogster
Post by kwhogster »
Still does not explain why it happens
of course a Timeout but why a timeout is the question.
You run a check_nrpe status and it returns everything is ok so why the services timeing out?
kwhogster wrote:Still does not explain why it happens
I bet the plugin is taking too long, or it's failing. Read the log files, they usually indicate what's going on and a good hunch on what to look for. That's probably the case if other plugins are working.
me@work55
Post by me@work55 »
Lets lock this one now
I am going to post another issue.
Setting up escalations that might help the amount of emails
Tom
