Radwin Radios SNMP
pmnykh
Re: Radwin Radios SNMP
Post by pmnykh »
[root@localhost libexec]# ./check_snmp -H 192.168.1.110 -o .1.3.6.1.4.1.4458.1000.1.5.56.2.0 -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des
SNMP OK - -63 | iso.3.6.1.4.1.4458.1000.1.5.56.2.0=-63
How can I add this task to the host check?
Host config file:
define host {
use linux-server
host_name radwin1
alias radwinradio1
address 192.168.1.110
max_check_attempts 3
check_interval 3
retry_interval 1
check_period 24x7
contacts nagiosadmin
notification_interval 60
notification_period 24x7
first_notification_delay 0
notifications_enabled 1
host_name radwin1
service_description PING
check_command check_ping!100.0,20%!500.0,60%
check_interval 3
retry_interval 1
check_period 24x7
When I tried to add
        use                                  generic-service
        host_name                       radwin1
        check_command              check_snmp -H 192.168.1.110 -o .1.3.6.1.4.1.4458.1000.1.5.56.2.0 -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des W -w 60 -c 70
I got
Checking objects...
Error: Service check command 'check_snmp -H 192.168.1.110 -o .1.3.6.1.4.1.4458.1000.1.5.56.2.0 -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des W -w 60 -c 70' specified in service 'PING' for host 'radwin1' not defined anywhere!
I guess that the MIB file and the PDF for that OID had mistakes in them. Glad you figured it out.
About the service check error.
First, in the commands.cfg file, create a check_snmp command like the following
       command_name                             check_snmp
       command_line                             $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
Then edit your service check and change the check_command from
to
check_snmp! -o .1.3.6.1.4.1.4458.1000.1.5.56.2.0 -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des -w 60 -c 70
That should work for you.
