NRPE on Amazon Linux
cybergene
Re: NRPE on Amazon Linux
Post by cybergene »
tgriep wrote:Can you post the nrpe.cfg file from the /etc/init folder?
I have a feeling it is the wrong file.
See attached.
nrpe.conf
(497 Bytes) Downloaded 490 times
This is what the init script is trying to run.
/usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -f
Can you run that command as root in a shell and see if it starts up?
cybergene
Post by cybergene »
tgriep wrote:This is what the init script is trying to run.
Nothing changes. I still can't get nrpe to run. Unrecognized service:
[root@ip-xx-xx-xx-xx ~]# service nrpe start
nrpe: unrecognized service
That error is caused by a missing service config file on your system but if the software compiled on your server, you should be able to start NRPE in daemon mode by running.
Did this run on your server?
cybergene
Post by cybergene »
It doesn't show anything :
Then I test nrpe:
/usr/local/nagios/libexec/check_nrpe -H localhost -c check_load
connect to address 127.0.0.1 port 5666: Connection refused
connect to host localhost port 5666: Connection refused
Run the ps command to see if it is running in on the server.
ps -ef |grep nrpe
Did you configure the firewall to allow port 5666 inbound traffic?
cybergene
Post by cybergene »
This is what I get:
root     21423 21185  0 15:25 pts/0    00:00:00 grep nrpe
The output of the PS command doesn't show the NRPE Agent running at all.
You would have to look at the log files to see why it didn't start up when you manually ran the command.
Take a look in the /var/log/messages log file to see why it didn't start up.
Or you can just install and run the older pre-compiled version of the Agent.
cybergene
Post by cybergene »
I don't see anything in the logs.
nrpe[21779]: Starting up daemon
Apr  3 nrpe[21779]: Server listening on 0.0.0.0 port 5666.
Apr  3 nrpe[21779]: Server listening on :: port 5666.
Apr  3 nrpe[21779]: Listening for connections on port 5666
Apr  3 nrpe[21779]: Allowing connections from: xx.xx.xxx.xx
but I still get the connection refused error.
I guess I have no other choice than installing the older version.
Try running it like this and see if it stays running on the system.
/usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -d
