Windows Server Not Showing Memory Usage in Nagios Xi Metrics
sarfarosh
Re: Windows Server Not Showing Memory Usage in Nagios Xi Met
Post by sarfarosh »
Hi Triep,
Can you please tell me that when can i expect the solution as the customer is facing the issue since last 3 months and we tried everything we can. I need to give them some timeline on when it will get resolved.
The next major release of Nagios XI is scheduled for July 2017 and hopefully is will be fixed in that release.
sarfarosh
Post by sarfarosh »
Hi Tgriep,
Thanks for all your support. Is it possible to provide solution for this issue little early because customer is getting panic as they need to do lot of manual work which is time consuming for them.
I'll submit a Bug fix for the issue and see if it can get done sooner.
sarfarosh
Post by sarfarosh »
Hi Tgriep,
Thank you. We are expecting it to be resolved at the earliest.
If I get any news, I'll post it here.
sarfarosh
Post by sarfarosh »
Hi Tgriep,
Thanks a lot. Also if possible do email me on "[email protected]" .
OK. I'll try.
sarfarosh
Post by sarfarosh »
Hi Tgriep,
Any progress on the issue ?
The Metrics component is going to be re-written in one of the future versions of Nagios XI. Our developers haven't determined yet in which one. It all depends on the priority of the current projects, and the length of our TODO list. I would suggest that you check our Product Roadmaps once in a while, in order to learn of the future developments.
