No graphing for HPUX NRPE checks
Re: No graphing for HPUX NRPE checks
here you go
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
- Former Nagios Staff
If you tried to attach something, it didn't work.
lol sorry
Proudly running:
Nagios Fusion
Nagios Fusion
It looks like the number data points for that check was changed since the graph was created and when that happens, the graphing will stop.
To fix this, login to the Nagios server as root and change to the following folfer. Replace <hostname> with the actual host
Then delete the following files.
Wait for 20 minutes for those files to be recreated and then login to the XI GUI and see if the graphs are populated with data.
cd /usr/local/nagios/share/perfdata/<hostname>Code: Select all
HPUX_disk_usage.xml
HPUX_disk_usage.rrdBe sure to check out our Knowledgebase for helpful articles and solutions!
