Nagios Service Output Displays Random Numbers
tps27
Re: Nagios Service Output Displays Random Numbers
Post by tps27 »
@tgriep Thank you! This solved the issue! Just two quick follow-up questions; do you know if there is a way to increase the spacing in the extend status information of Nagios Core on its front end? Or if there is an option to bold certain parts of the output?
I am glad that it it working for you now.
There is a limitation in older versions of the NRPE Agent and the check_nrpe command that will only transfer 1024 bytes of information and that could be cutting off the status output.
Can you run the command in a shell and see if it returns all of the data or if it truncates the output and let us know?
