ERROR: rsyslog configuration check failed.
Kumar_pinkesh
Re: ERROR: rsyslog configuration check failed.
Post by Kumar_pinkesh »
After changing the port to 5545 , still logs are not moving.
cdienger
Post by cdienger »
Make sure that port 5545 was opened on the NLS with:
netstat -na | grep 5545
You may need to open it:
iptables -I INPUT 1 -p tcp --dport 5545 -j ACCEPT
Finally, can you see traffic coming in on that port if you run:
yum -y install tcpdump
tcpdump port 5545
The above installs tcpdump and then listens on port 5545. Any network traffic coming in on port 5545 will be displayed on the screen.
