This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
- Madmin
Post
by tgriep »
OK, lets just set it to 4096 by running the following.
echo "use nagios;alter table nagios_logentries modify logentry_data varchar(4096) not null;" | mysql -pnagiosxi
Be sure to check out our
Knowledgebase for helpful articles and solutions!
ahoward12
Post
by ahoward12 »
Ok that one worked! I'll keep you updated.
- Madmin
Post
by tgriep »
OK, thanks.
ahoward12
Post
by ahoward12 »
Just wanted to update; apparently the log entry data field increase fixed the issues. This can be closed. As always, thank you
Post
by scottwilkerson »
Thanks for following up!
