Set the command name to
check_snmp_hp-procurve-countersCode: Select all
$USER1$/check_snmp_hp-procurve-counters.sh $HOSTADDRESS$ $ARG1$Save it
Then you can go to the Service menu and create a service that uses the check_snmp_hp-procurve-counters command and in $ARG1$ you would put the community string.
Make sure you select a template for that service or that you will in the required options.
Save it and Apply the Config and that device will be checked at the next scheduled time.
