Monitoring of Linux Host--Could not complete SSL handshake
amitgupta19
Re: Monitoring of Linux Host--Could not complete SSL handsha
Post by amitgupta19 »
@cdienger
Yes i am able to install the Nagios Plugin and NRPE Agent sucessfully.
Thanks for the support.
Can you please also help me understand the following command:
command[check_load]=/usr/local/nagios/libexec/check_load -r -w 15,10,5 -c 30,25,20
This command is giving the system average load over 5, 10 and 15 minutes.
But i am not able to understand what is 15,10 and 5 in W. 30,25,20 in C?
Below is the current data from the Nagios console, with the thresholds as set above.
Status Information: WARNING - load average per CPU: 0.10, 0.14, 0.16
Performance Data: load1=0.095;0.150;0.300;0; load5=0.135;0.100;0.250;0; load15=0.158;0.050;0.200;0;
With the above thresholds the data is showing as warning. But i am not able to understand why it is showing warning.Please help me understand
When do you see this output - when you run the check "locally" on the remote box:
or when you call the command via check_nrpe?
./check_nrpe -H <client ip> -c check_load
Can you run the following commands on the remote box, and show the output?
uptime
echo $?
Did you check to see if you don't have the "check_load" command defined twice? Have you restarted nrpe service (or xinetd) after modifying the "check_load" command?
