ZEVENET Monitoring not returning Data
Re: ZEVENET Monitoring not returning Data
Most of the messages were warnings telling you that to install that package, you need to install other packages first.
Go through the list, install those first and then continue on.
lpereira
Post by lpereira »
I was asked to install "perl -MCPAN -e 'install Monitoring::Plugin' "
but i don't think is necessary due the VM is the one Nagios provide. could you please confirm if not necessary?
lpereira wrote:I was asked to install "perl -MCPAN -e 'install Monitoring::Plugin' "
It may be required for some plugins. Our VM has the package Nagios::Monitoring::Plugin installed by default, but if a plugin author uses Monitoring::Plugin you would either need the package or need to modify the plugin to use Nagios::Monitoring::Plugin
lpereira
Post by lpereira »
great, so it would not "harm" the actual monitoring, right?
npolovenko
Post by npolovenko »
@lpereira, Nope, I don't see how it could harm Nagios. You can always uninstall it if you'd like.
lpereira
Post by lpereira »
I have installed the package YAML but still having issues with the output
Running Transaction
  Installing : libyaml-0.1.3-4.el6_6.x86_64        1/2
  Installing : PyYAML-3.10-3.1.el6.x86_64        2/2
  Verifying  : libyaml-0.1.3-4.el6_6.x86_64        1/2
  Verifying  : PyYAML-3.10-3.1.el6.x86_64        2/2
Installed:
  PyYAML.x86_64 0:3.10-3.1.el6
Dependency Installed:
  libyaml.x86_64 0:0.1.3-4.el6_6
Complete!
[root@nagios libexec]# sudo perl check_zevenet_cpu.pl -H HostIP -z Zapikey -w 20 -c 10
Can't use an undefined value as filehandle reference at check_zevenet_cpu.pl line 179.
One fix I found after searching, try changing this line from
$retcode = $curl->perform;
to
my $retcode = $curl->perform;
and see if it fixes the issue.
lpereira
Post by lpereira »
tgriep wrote:One fix I found after searching, try changing this line from
to
This is what i have on the plugin
#  ZAPI v3 call
my $response_body;
my $retcode;
my $response_code;
my $response_decoded;
my $curl = WWW::Curl::Easy->new;
$curl->setopt(CURLOPT_HEADER,0);
$curl->setopt(CURLOPT_SSL_VERIFYPEER, 0);
$curl->setopt(CURLOPT_SSL_VERIFYHOST, 0);
# Maximun time that a given cURL operation should only take
$curl->setopt(CURLOPT_TIMEOUT, $p->opts->timeout);
$curl->setopt(CURLOPT_URL, ("https://$host:$port$url"));
my @authHeader = ( 'Content-Type: application/json', "ZAPI_KEY: $zapikey");
$curl->setopt(CURLOPT_HTTPHEADER, \@authHeader);
# A filehandle, reference to a scalar or reference to a typeglob can be used here.
$curl->setopt(CURLOPT_WRITEDATA,\$response_body);
# Starts the actual request
and i modifed with
#  ZAPI v3 call
my $response_body;
# my $retcode;
my $response_code;
Still having the same output:
I think there is one more module that did not get updated. Try running this to install the WWW::Curl::Easy module.
cpan -i WWW::Curl::Easy
Test the check again and see is it works.
Please post how you ran the check.
lpereira
Post by lpereira »
tgriep wrote:I think there is one more module that did not get updated. Try running this to install the WWW::Curl::Easy module.
Here is the complete output:
CPAN: Storable loaded ok (v2.20)
Going to read '/root/.cpan/Metadata'
  Database was generated on Wed, 14 Feb 2018 18:17:03 GMT
Running install for module 'WWW::Curl::Easy'
CPAN: Data::Dumper loaded ok (v2.124)
'YAML' not installed, falling back to Data::Dumper and Storable to read prefs '/root/.cpan/prefs'
Running make for S/SZ/SZBALINT/WWW-Curl-4.17.tar.gz
CPAN: Digest::SHA loaded ok (v5.47)
CPAN: Compress::Zlib loaded ok (v2.021)
Checksum for /root/.cpan/sources/authors/id/S/SZ/SZBALINT/WWW-Curl-4.17.tar.gz ok
WWW-Curl-4.17/
WWW-Curl-4.17/LICENSE
WWW-Curl-4.17/META.yml
WWW-Curl-4.17/typemap
WWW-Curl-4.17/template/
WWW-Curl-4.17/template/Easy.pm.tmpl
WWW-Curl-4.17/template/Share.pm.tmpl
WWW-Curl-4.17/lib/
WWW-Curl-4.17/lib/WWW/
WWW-Curl-4.17/lib/WWW/Curl/
WWW-Curl-4.17/lib/WWW/Curl/Form.pm
WWW-Curl-4.17/lib/WWW/Curl/Multi.pm
WWW-Curl-4.17/lib/WWW/Curl/Easy.pm
WWW-Curl-4.17/lib/WWW/Curl/Share.pm
WWW-Curl-4.17/lib/WWW/Curl.pm
WWW-Curl-4.17/README.Win32
WWW-Curl-4.17/Curl.xs
WWW-Curl-4.17/Makefile.PL
WWW-Curl-4.17/MANIFEST
WWW-Curl-4.17/inc/
WWW-Curl-4.17/inc/Module/
WWW-Curl-4.17/inc/Module/Install.pm
WWW-Curl-4.17/inc/Module/Install/
WWW-Curl-4.17/inc/Module/Install/MakeMaker.pm
WWW-Curl-4.17/inc/Module/Install/Metadata.pm
WWW-Curl-4.17/inc/Module/Install/External.pm
WWW-Curl-4.17/inc/Module/Install/Base.pm
WWW-Curl-4.17/inc/Module/Install/Makefile.pm
WWW-Curl-4.17/inc/Module/Install/Can.pm
WWW-Curl-4.17/t/
WWW-Curl-4.17/t/06http-post.t
WWW-Curl-4.17/t/07ftp-upload.t
WWW-Curl-4.17/t/17slist.t
WWW-Curl-4.17/t/21write-to-scalar.t
WWW-Curl-4.17/t/symbols-in-versions
WWW-Curl-4.17/t/05progress.t
WWW-Curl-4.17/t/19multi.t
WWW-Curl-4.17/t/pod.t
WWW-Curl-4.17/t/15duphandle-callback.t
WWW-Curl-4.17/t/10errbuf.t
WWW-Curl-4.17/t/02callbacks.t
WWW-Curl-4.17/t/pod-coverage.t
WWW-Curl-4.17/t/14duphandle.t
WWW-Curl-4.17/t/18twinhandles.t
WWW-Curl-4.17/t/04abort-test.t
WWW-Curl-4.17/t/new/
WWW-Curl-4.17/t/new/07errbuf.t
WWW-Curl-4.17/t/new/08duphandle.t
WWW-Curl-4.17/t/new/06http-post.t
WWW-Curl-4.17/t/new/03body-callback.t
WWW-Curl-4.17/t/new/04abort.t
WWW-Curl-4.17/t/new/02header-callback.t
WWW-Curl-4.17/t/new/05progress.t
WWW-Curl-4.17/t/new/10multi-callback.t
WWW-Curl-4.17/t/new/09duphandle-callback.t
WWW-Curl-4.17/t/new/README
WWW-Curl-4.17/t/new/01basic.t
WWW-Curl-4.17/t/new/00constants.t
WWW-Curl-4.17/t/meta.t
WWW-Curl-4.17/t/09times.t
WWW-Curl-4.17/t/08ssl.t
WWW-Curl-4.17/t/20undefined_subs.t
WWW-Curl-4.17/t/01basic.t
WWW-Curl-4.17/t/13slowleak.t
WWW-Curl-4.17/t/16formpost.t
WWW-Curl-4.17/t/00constants.t
WWW-Curl-4.17/Changes
CPAN: File::Temp loaded ok (v0.22)
  CPAN.pm: Going to build S/SZ/SZBALINT/WWW-Curl-4.17.tar.gz
Locating required external dependency bin:curl-config... found at /usr/bin/curl-config.
The version is libcurl 7.19.7
Found curl.h in /usr/include/curl/curl.h
Building curlopt-constants.c for your libcurl version
Building Easy.pm constants for your libcurl version
Building Share.pm constants for your libcurl version
Checking if your kit is complete...
Looks good
Generating a Unix-style Makefile
Writing Makefile for WWW::Curl
Writing MYMETA.yml and MYMETA.json
Could not read '/root/.cpan/build/WWW-Curl-4.17-47QVhy/MYMETA.yml'. Falling back to other methods to determine prerequisites
cp lib/WWW/Curl/Share.pm blib/lib/WWW/Curl/Share.pm
cp lib/WWW/Curl/Form.pm blib/lib/WWW/Curl/Form.pm
cp lib/WWW/Curl/Multi.pm blib/lib/WWW/Curl/Multi.pm
cp lib/WWW/Curl/Easy.pm blib/lib/WWW/Curl/Easy.pm
cp lib/WWW/Curl.pm blib/lib/WWW/Curl.pm
Running Mkbootstrap for Curl ()
chmod 644 "Curl.bs"
"/usr/bin/perl" "-Iinc" -MExtUtils::Command::MM -e 'cp_nonempty' -- Curl.bs blib/arch/auto/WWW/Curl/Curl.bs 644
"/usr/bin/perl" "-Iinc" "/usr/share/perl5/ExtUtils/xsubpp"  -typemap '/usr/share/perl5/ExtUtils/typemap' -typemap '/root/.cpan/build/WWW-Curl-4.17-47QVhy/typemap'  Curl.xs > Curl.xsc
mv Curl.xsc Curl.c
gcc -c  -I/usr/include -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic   -DVERSION=\"4.17\" -DXS_VERSION=\"4.17\" -fPIC "-I/usr/lib64/perl5/CORE"   Curl.c
rm -f blib/arch/auto/WWW/Curl/Curl.so
LD_RUN_PATH="/usr/lib64" gcc  -shared -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic  Curl.o  -o blib/arch/auto/WWW/Curl/Curl.so  \
	   -lcurl   \
chmod 755 blib/arch/auto/WWW/Curl/Curl.so
Manifying 1 pod document
  /usr/bin/make -- OK
Warning (usually harmless): 'YAML' not installed, will not store persistent state
Running make test
PERL_DL_NONLAZY=1 "/usr/bin/perl" "-MExtUtils::Command::MM" "-MTest::Harness" "-e" "undef *Test::Harness::Switches; test_harness(0, 'inc', 'blib/lib', 'blib/arch')" t/*.t
t/00constants.t ........... ok
t/01basic.t ...............
Dubious, test returned 4 (wstat 1024, 0x400)
Failed 4/19 subtests
t/02callbacks.t ...........
Dubious, test returned 2 (wstat 512, 0x200)
Failed 2/7 subtests
t/04abort-test.t ..........
Dubious, test returned 1 (wstat 256, 0x100)
Failed 1/8 subtests
t/05progress.t ............
Dubious, test returned 3 (wstat 768, 0x300)
Failed 3/16 subtests
t/06http-post.t ........... skipped: Not performing http POST/upload tests
t/07ftp-upload.t .......... skipped: Not performing ftp upload tests
t/08ssl.t .................
Dubious, test returned 9 (wstat 2304, 0x900)
Failed 9/19 subtests
t/09times.t ...............
Dubious, test returned 6 (wstat 1536, 0x600)
t/10errbuf.t .............. ok
t/13slowleak.t ............ skipped: Not performing slow leakage regression test
t/14duphandle.t ...........
Failed 3/17 subtests
t/15duphandle-callback.t ..
Dubious, test returned 7 (wstat 1792, 0x700)
Failed 7/25 subtests
t/16formpost.t ............ skipped: Not performing POST
t/17slist.t ............... skipped: Not performing printenv cgi tests
t/18twinhandles.t .........
Failed 3/12 subtests
t/19multi.t ............... ok
t/20undefined_subs.t ...... ok
t/21write-to-scalar.t .....
t/meta.t .................. skipped: Test::CPAN::Meta required for testing META.yml
t/pod-coverage.t .......... skipped: Test::Pod::Coverage 1.04 required for testing POD coverage
t/pod.t ................... skipped: Test::Pod 1.14 required for testing POD
Test Summary Report
t/01basic.t             (Wstat: 1024 Tests: 19 Failed: 4)
  Failed tests:  14-15, 17, 19
  Non-zero exit status: 4
t/02callbacks.t         (Wstat: 512 Tests: 7 Failed: 2)
  Failed tests:  6-7
  Non-zero exit status: 2
t/04abort-test.t        (Wstat: 256 Tests: 8 Failed: 1)
  Failed test:  8
  Non-zero exit status: 1
t/05progress.t          (Wstat: 768 Tests: 16 Failed: 3)
  Failed tests:  14-16
  Non-zero exit status: 3
t/08ssl.t               (Wstat: 2304 Tests: 19 Failed: 9)
  Failed tests:  8-9, 11-17
  Non-zero exit status: 9
t/09times.t             (Wstat: 1536 Tests: 16 Failed: 6)
  Failed tests:  11-16
  Non-zero exit status: 6
  Parse errors: Bad plan.  You planned 19 tests but ran 16.
t/14duphandle.t         (Wstat: 768 Tests: 17 Failed: 3)
  Failed tests:  12-13, 16
t/15duphandle-callback.t (Wstat: 1792 Tests: 25 Failed: 7)
  Failed tests:  14-17, 19, 24-25
  Non-zero exit status: 7
t/18twinhandles.t       (Wstat: 768 Tests: 12 Failed: 3)
  Failed tests:  10-12
t/21write-to-scalar.t   (Wstat: 768 Tests: 12 Failed: 3)
  Failed tests:  9-10, 12
Files=22, Tests=729,  2 wallclock secs ( 0.08 usr  0.03 sys +  0.54 cusr  0.10 csys =  0.75 CPU)
Result: FAIL
  /usr/bin/make test -- NOT OK
//hint// to see the cpan-testers results for installing this module, try:
  reports SZBALINT/WWW-Curl-4.17.tar.gz
Running make install
  make test had returned bad status, won't install without force
Seems that it didn't like it that much
