NRPE on ubuntu 16 not working
tcanthonyii
Re: NRPE on ubuntu 16 not working
The check commands I sent were from the remote host. I ran the wizard and instructions to get it working. What step did I miss to not populate all of the checks from the wizard?
I always prefer arguments to hard coded checks. At this point I don't really care I just want the checks I created with the wizard to work.
kyang
Which wizard are you using? NRPE wizard or Linux wizard?
Make sure you have the same commands defined on your XI server as well, and then restart NRPE.
The NRPE wizard allows you to pass the check through the command.
https://assets.nagios.com/downloads/nag ... g_NRPE.pdf
The Linux wizard (which also uses NRPE or xinetd) is probably what you are looking for as it has more pre-defined checks.
https://assets.nagios.com/downloads/nag ... g-NRPE.pdf
Let me know if this helps.
tcanthonyii
I used the second link. The issue is on the monitored server all the checks fail because the checks are not defined in the nrpe file. I followed the wizard and the attached 2nd link above and still a no go. I just need to add those checks from the wizard into the NRPE file on the far end monitored server but I don't know how and it's not listed in the documentation.
kyang
Could you please post your nrpe.cfg for the remote server?
Also, your XI nrpe.cfg as well.
Thanks!
Thanks!
tcanthonyii
This is the far end server:
This is the nagios serve from /usr/local/nagios/etc/nrpe.cfg:
# Sample NRPE Config File
# Written by: Ethan Galstad ([email protected])
# Last Modified: 11-23-2007
# NOTES:
# This is a sample configuration file for the NRPE daemon. It needs to be
# located on the remote host that is running the NRPE daemon, not the host
# from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number. The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/var/run/nagios/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
# (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently
# supported.
# Note: The daemon only does rudimentary checking of the client's IP
# address. I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
allowed_hosts=127.0.0.1,192.168.1.190
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed. This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=1
# BASH COMMAND SUBTITUTION
# to specify arguments that contain bash command substitutions of the form
# $(...). This option only works if the daemon was configured with both
# the --enable-command-args and --enable-bash-command-substitution configure
# script options.
# *** ENABLING THIS OPTION IS A HIGH SECURITY RISK! ***
# Values: 0=do not allow bash command substitutions,
# 1=allow bash command substitutions
allow_bash_command_substitution=0
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo. For this to work, you need to add
# the nagios user to your /etc/sudoers. An example entry for alllowing
# execution of the plugins from might be:
# nagios ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password. If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# wait for a connection to be established before exiting. This is sometimes
# seen where a network problem stops the SSL being established even though
# all network sessions are connected. This causes the nrpe daemons to
# accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEEK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# COMMAND DEFINITIONS
# Command definitions that this daemon will run. Definitions
# are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name>
# it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be
# typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside
# on the machine that this daemon is running on! The examples below
# assume that you have plugins installed in a /usr/local/nagios/libexec
# directory. Also note that you will have to modify the definitions below
# to match the argument format the plugins expect. Remember, these are
# examples only!
# The following examples use hardcoded command arguments...
command[check_users]=/usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_load]=/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
command[check_hda1]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/hda1
command[check_zombie_procs]=/usr/lib/nagios/plugins/check_procs -w 5 -c 10 -s Z
command[check_total_procs]=/usr/lib/nagios/plugins/check_procs -w 150 -c 200
# The following examples allow user-supplied arguments and can
# only be used if the NRPE daemon was compiled with support for
# command arguments *AND* the dont_blame_nrpe directive in this
# config file is set to '1'. This poses a potential security risk, so
# make sure you read the SECURITY file before doing this.
command[check_users]=/usr/lib/nagios/plugins/check_users -w $ARG1$ -c $ARG2$
command[check_load]=/usr/lib/nagios/plugins/check_load -w $ARG1$ -c $ARG2$
command[check_disk]=/usr/lib/nagios/plugins/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
command[check_procs]=/usr/lib/nagios/plugins/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
# local configuration:
# if you'd prefer, you can instead place directives here
include=/etc/nagios/nrpe_local.cfg
# you can place your config snipplets into nrpe.d/
# only snipplets ending in .cfg will get included
include_dir=/etc/nagios/nrpe.d/
# NOTES:
# LOG FACILITY
log_facility=daemon
# PID FILE
pid_file=/var/run/nrpe.pid
# PORT NUMBER
server_port=5666
# SERVER ADDRESS
# NRPE USER
nrpe_user=nagios
# NRPE GROUP
nrpe_group=nagios
# supported.
# option.
dont_blame_nrpe=0
# script options.
# COMMAND PREFIX
# Usage scenario:
# DEBUGGING OPTION
# syslog facility.
debug=0
# COMMAND TIMEOUT
command_timeout=60
# examples only!
command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/hda1
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
kyang
From your Nagios service nrpe.cfg
Can you uncomment these, and restart the NRPE service.
Then rerun the Linux server wizard and let me know if it worked or not. Thanks!
#command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$-
tcanthonyii
I have a few other linux servers running on this host. I shouldn't have to monkey with the NRPE agent on the server.
I did some more checking at my working servers and the calls look like this:
[nagios@NagiosXIMon ~]$ /usr/local/nagios/libexec/check_nrpe -H 192.168.8.19 -t 30 -c check_cpu_stats -a '-w 85 -c 95'
Am I right in thinking it's using Check_NRPE as the command and passing the argument check_cpu_stats? if so check_nrpe does not exist in /usr/local/nagios/libexec. MANY other checks do but not check_nrpe. I also looked at one of the working servers nrpe file and check_cpu_stats is not defined in the file but it does pull appropriate stats.
So I copied in a check_nrpe file from a working server but it's still not working (file is from centos and I'm running ubuntu) so that may be a problem. I think the real issue is that check_nrpe is missing. HOw do I get the correct check_nrpe file in the directory? Even all the wizard checks run check_nrpe
tcanthonyii
Also how do I restart nrpe service on nagiosxi?
kyang
To install the plugin only on Ubuntu, follow these commands.
I got them from our source install kb article. (Scroll all the way to the bottom)
https://support.nagios.com/kb/article.php?id=515
Is the XI NRPE on CentOS?
To restart NRPE is either one of the two commands. Depends on how you have it installed.
sudo apt-get update
sudo apt-get install -y autoconf gcc libc6 libmcrypt-dev make libssl-dev wgetCode: Select all
cd /tmp
wget --no-check-certificate -O nrpe.tar.gz https://github.com/NagiosEnterprises/nrpe/archive/nrpe-3.2.1.tar.gz
tar xzf nrpe.tar.gz
cd /tmp/nrpe/
./configure
make check_nrpe
make install-pluginTo restart NRPE is either one of the two commands. Depends on how you have it installed.
service nrpe restart
service xinetd restart-
tcanthonyii
OK so I ran the commands. I now have the check_nrpe. Yay! I restarted nrpe on both the xi server and the the server I want monitored. Still getting the same error:
[root@NagiosXIMon libexec]# ./check_nrpe -H 192.168.8.19 -t30 -c check_cpu_stats -a '-w 85 -c 95'
NRPE: Command 'check_cpu_stats' not defined
Where is this check_cpu_stats defined? It's not in the nrpe.cfg file obviously. Same goes for check_mem same for check_init_service etc.
