Hi
No, i still not receive emails notifications.
Nagios email alerts.
Re: Nagios email alerts.
according to this log lines it was accepted for delivery to [email protected]
If you aren't receiving these messages, I would check your spam filter, or ultimately contact google.com as they run the server that accepted the messages with 250 2.0.0 OKKnack wrote:Code: Select all
Feb 21 23:59:41 in-nagios postfix/pickup[8756]: 82CF8C07AAE3: uid=1000 from=<nagios> Feb 21 23:59:41 in-nagios postfix/cleanup[25022]: 82CF8C07AAE3: message-id=<[email protected]> Feb 21 23:59:41 in-nagios postfix/qmgr[30807]: 82CF8C07AAE3: from=<[email protected]>, size=692, nrcpt=1 (queue active) Feb 21 23:59:43 in-nagios postfix/smtp[25026]: connect to aspmx.l.google.com[2404:6800:4003:c03::1a]:25: Network is unreachable Feb 21 23:59:44 in-nagios postfix/smtp[25026]: 82CF8C07AAE3: to=<[email protected]>, relay=aspmx.l.google.com[74.125.24.26]:25, delay=3.2, delays=0.11/0.01/2.2/0.83, dsn=2.0.0, status=sent (250 2.0.0 OK 1519237784 4-v6si12439603plc.92 - gsmtp) Feb 21 23:59:44 in-nagios postfix/qmgr[30807]: 82CF8C07AAE3: removed Feb 21 23:59:56 in-nagios postfix/pickup[8756]: 8D4B7C07AAE3: uid=1000 from=<nagios> Feb 21 23:59:56 in-nagios postfix/cleanup[25022]: 8D4B7C07AAE3: message-id=<[email protected]> Feb 21 23:59:56 in-nagios postfix/qmgr[30807]: 8D4B7C07AAE3: from=<[email protected]>, size=691, nrcpt=1 (queue active) Feb 21 23:59:57 in-nagios postfix/smtp[25026]: 8D4B7C07AAE3: to=<[email protected]>, relay=aspmx.l.google.com[74.125.24.26]:25, delay=1.2, delays=0.05/0/0.62/0.56, dsn=2.0.0, status=sent (250 2.0.0 OK 1519237797 g8-v6si1897205plt.687 - gsmtp) Feb 21 23:59:57 in-nagios postfix/qmgr[30807]: 8D4B7C07AAE3: removed Feb 22 00:13:11 in-nagios postfix/pickup[8756]: 84D15C07AAE3: uid=1000 from=<nagios> Feb 22 00:13:11 in-nagios postfix/cleanup[7158]: 84D15C07AAE3: message-id=<[email protected]> Feb 22 00:13:11 in-nagios postfix/qmgr[30807]: 84D15C07AAE3: from=<[email protected]>, size=692, nrcpt=1 (queue active) Feb 22 00:13:12 in-nagios postfix/smtp[7160]: connect to aspmx.l.google.com[2404:6800:4003:c03::1b]:25: Network is unreachable Feb 22 00:13:13 in-nagios postfix/smtp[7160]: 84D15C07AAE3: to=<[email protected]>, relay=aspmx.l.google.com[74.125.200.26]:25, delay=2.4, delays=0.07/0.01/1.6/0.76, dsn=2.0.0, status=sent (250 2.0.0 OK 1519238593 x1si264315pgv.124 - gsmtp) Feb 22 00:13:13 in-nagios postfix/qmgr[30807]: 84D15C07AAE3: removed Feb 22 00:13:21 in-nagios postfix/pickup[8756]: 99AB2C07AAE3: uid=1000 from=<nagios> Feb 22 00:13:21 in-nagios postfix/cleanup[7158]: 99AB2C07AAE3: message-id=<[email protected]> Feb 22 00:13:21 in-nagios postfix/qmgr[30807]: 99AB2C07AAE3: from=<[email protected]>, size=691, nrcpt=1 (queue active) Feb 22 00:13:22 in-nagios postfix/smtp[7160]: 99AB2C07AAE3: to=<[email protected]>, relay=aspmx.l.google.com[74.125.200.26]:25, delay=1.3, delays=0.07/0/0.59/0.59, dsn=2.0.0, status=sent (250 2.0.0 OK 1519238602 j76si31174pfj.146 - gsmtp) Feb 22 00:13:22 in-nagios postfix/qmgr[30807]: 99AB2C07AAE3: removed Feb 22 00:45:01 in-nagios postfix/pickup[8756]: 459E8C07AAE3: uid=1000 from=<nagios> Feb 22 00:45:01 in-nagios postfix/cleanup[8866]: 459E8C07AAE3: message-id=<[email protected]> Feb 22 00:45:01 in-nagios postfix/qmgr[30807]: 459E8C07AAE3: from=<[email protected]>, size=692, nrcpt=1 (queue active) Feb 22 00:45:03 in-nagios postfix/smtp[8872]: 459E8C07AAE3: to=<[email protected]>, relay=aspmx.l.google.com[74.125.24.27]:25, delay=2.5, delays=0.05/0/1.6/0.83, dsn=2.0.0, status=sent (250 2.0.0 OK 1519240503 72-v6si3095965ple.299 - gsmtp) Feb 22 00:45:03 in-nagios postfix/qmgr[30807]: 459E8C07AAE3: removed Feb 22 00:45:30 in-nagios postfix/pickup[8756]: 44945C07AAE3: uid=1000 from=<nagios> Feb 22 00:45:30 in-nagios postfix/cleanup[8866]: 44945C07AAE3: message-id=<[email protected]> Feb 22 00:45:30 in-nagios postfix/qmgr[30807]: 44945C07AAE3: from=<[email protected]>, size=696, nrcpt=1 (queue active) Feb 22 00:45:31 in-nagios postfix/smtp[8872]: 44945C07AAE3: to=<[email protected]>, relay=aspmx.l.google.com[74.125.24.27]:25, delay=1.3, delays=0.06/0/0.63/0.56, dsn=2.0.0, status=sent (250 2.0.0 OK 1519240531 w24-v6si7752487pll.479 - gsmtp)
yes, it seems perfect. but where the emails stuck. spam folder also empty.
How can i check this (contact google.com as they run the server that accepted the messages with 250 2.0.0 OK)
being your domain email is hosted at google I'm guessing you have G-Suite
https://gsuite.google.com/support/
its working when i change my local lan ip to another ISP.
Thanks for your all replies.
glad it's working!
