LDAP 0 users to import
cdienger
Re: LDAP 0 users to import
Post by cdienger »
There are two places(line 700 AND 443) in index.php that define the user types and we have only edit one to my knowledge thus far. I've setup an object (not a typical user object) and was able to get it to display as a user by editing these two lines. Add hpemployee, hpperson, ntuser the the list of types and units, test, and let me know your results.
dmhp
Post by dmhp »
The latest changes didn't make a visual difference.
We'll just stick to the manual method, as access based on ldap groups is not available, its less important.
cdienger
Post by cdienger »
Thank you for the update. As I mentioned before, ldap setups can be tricky and this turned out to be especially true here. Sorry we couldn't get to the root of it but fortunately we found a work around that works for you.
dmhp
Post by dmhp »
cdienger wrote:Thank you for the update. As I mentioned before, ldap setups can be tricky and this turned out to be especially true here. Sorry we couldn't get to the root of it but fortunately we found a work around that works for you.
Thanks for the help.
