FUSION disk full 5-6 days after starting new server
This support forum board is for questions relating to Nagios Fusion.
Re: FUSION disk full 5-6 days after starting new server
Can you open the nagiosfusion crontab file
/etc/cron.d/nagiosfusion
Verify that this entry is in there
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosfusion/cron/dbmaint_subsys.php >>/usr/local/nagiosfusion/var/log/dbmaint_subsys.log 2>&1
If not, add it and restart cron by running
service crond restart
Then see if it runs and that it truncates the MYSQL tables.
If the entry was there, let us know.
dlukinski
Post by dlukinski »
tgriep wrote:Can you open the nagiosfusion crontab file
line is there.
We've lost more free space since yesterday. How to cleanup?
[root@fikc-nagfsprod01 cron.d]# df -h
/dev/mapper/VolGroup-lv_root
37G 27G 8.8G 75% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
/dev/sda1 477M 122M 330M 27% /boot
/dev/sr0 56M 56M 0 100% /mnt
Thank you for reporting back what you found on the your server. I would like you to run the following commands on your server and post the /tmp/info.txt file.
echo 'select * from options ;' |mysql -u fusion -pfusion fusion |grep reten >/tmp/info.txt
echo 'select * from polled_data;' |mysql -u fusion -pfusion fusion >>/tmp/info.txt
echo 'select polled_data_id from  polled_extras;' |mysql -u fusion -pfusion fusion >>/tmp/info.txt
To truncate the database and shrink it, run the following as root
cd /usr/local/nagiosfusion/scripts
./truncate_polled.php
echo 'OPTIMIZE TABLE polled_extras;' |mysql -u fusion -pfusion fusion
dlukinski
Post by dlukinski »
tgriep wrote:Thank you for reporting back what you found on the your server. I would like you to run the following commands on your server and post the /tmp/info.txt file.
Updated info.txt attached.
Thank you for truncation commands: worked.
[root@fikc-nagfsprod01 scripts]# df -h
37G 3.3G 32G 10% /
Thanks for the data.
Your system is keeping a lot of extra polled_data which in turn keeps extra polled_extra data so a new component was created to remove the older data that is not needed anymore.
To be safe, make a snapshot of the server in case you need to revert.
Attached to this post is a zip file called trimpolled.zip.
Save it to your desktop and go to the Admin > Manage Components menu in Fusion, browse to it and Upload it to the server.
Let the system run for 10 minutes and run the following as root.
This should automatically truncate and optimize the tables in the MYSQL database which should shrink them further.
Then, once a week, it will optimize the data when the script is ran so you will see the database increase a bit for a week then shrink again.
Let us know if it works and how much it shrinks the database.
dlukinski
Post by dlukinski »
tgriep wrote:Thanks for the data.
Believe this is now fully resolved.
Thank you so much for all the time spent!
eloyd
Cool Title Here
Post by eloyd »
Glad we could all help you.
Your welcome. Glad to help. I'll close the post for you but if you have any issues or questions in the future, feel free to open a new post.
