NRDS windows problems
Re: NRDS windows problems
Can you zip this whole directory and sent it to me?
C:\Program Files\Nagios\NRDS_Win
morabanc
Post by morabanc »
Here you are.
Where did you get this NRDS_Win from? It is running a pre-release version. I couldn't have been built from the NRDS Section of the XI system I don't believe...
If it was, what version of XI are you running?
morabanc
Post by morabanc »
I get the NRDS installation from my NagiosXI (look at the picture).
Our Nagios version is "Nagios XI 2014R2.0"
I changed this paramethers to test, the correct IP is 192.168.1.1 and token 05lpuur3xd2o.
Have you added this token to your NRDP Settings on the Nagios XI server (Inbound Check Transfer Settings page; NRDP tab)? I don't see it in the screenshot you showed us...
Also, the URL to the nrdp server is defined as:
URL=http://192.168.1.1/nrdp/
however, on the "Inbound Check Transfer Settings" page, I can see a different IP address...
morabanc
Post by morabanc »
Hi lmitchev,
Because I try to another nagios server.
The correct is 192.168.1.1 with token 05lpuur3xd2o.
As scottwilkerson said, I can unistall all NRDS and intall it from this website https://exchange.nagios.org/directory/A ... in/details.
What do you think ?
I would recommend upgrading your Nagios XI server to the latest version (5.4.13 at the moment). This would upgrade NRDS as well.
Then, you could re-download the NRDS_Win_64.exe file from the Nagios XI server (under the NRDS Config Manager), and install NRDS client on the Windows machine (after uninstalling the old version).
Let us know if this helped.
morabanc
Post by morabanc »
Thanks lmitchev, we will do this :)
After upgrade I will test NRDS once again and if i have problems i will let you know.
Thanks and have a nice weekend
Sounds good @morabanc! We will keep the thread open for the time being. Let us know how it went. You have a nice weekend too!
