Plugin check not working
Re: Plugin check not working
kwhogster wrote:The command works from the nagios server via command line
Can you re-share the current configuration for the service (copy/paste)?
We need to verify it is running exactly what you are running from the CLI
Also your command definition for check_nrpe
kwhogster
Post by kwhogster »
My Service
host_name TGCS014-N1
service_description Default Web Site Connections
check_interval 60
notification_interval 60
check_command check_nrpe!Check_iis_conn! -a 'TGCS014-N1' 'Default Web Site' '5' '9'
servicegroups WEBServices
My NRPE Command
command_name check_nrpe
command_line /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARG1$ $ARG2$ $ARG3$ $ARG4$
From the CLI
root@tgcs017:/usr/local/nagios/etc/objects# /usr/local/nagios/libexec/./check_nrpe -H xx.x.x.x -t 60 -c check_iis_conn -a 'TGCS014-N1' 'Default Web Site' '5' '10'
CONNECTIONS OK Default Web Site connections 0 |'connections'=0;5;10
From Powershell on the server
PS C:\program files\nsclient++\scripts\powershell> .\check_iis_connections.ps1 tgcs014-n1 'default web site' 5 9
CONNECTIONS OK default web site connections 0 | connections=0;5;9;
HTH
Tom
These do not match
If the config you have Check_iis_conn
run from the command line check_iis_conn
Note the capital C in the config
kwhogster
Post by kwhogster »
Command line with upper case C works
root@tgcs017:/usr/local/nagios/etc/objects/windowsservers# /usr/local/nagios/libexec/./check_nrpe -H 10.2.8.28 -t 60 -c Check_iis_conn -a 'TGCS014-N1' 'Default Web Site' '5' '10'
Also changed it to lower case in the cfg file still same error
npolovenko
Post by npolovenko »
@kwhogster, Let's try the following. On the remote server please change the command to look like this:
check_iis_conn = cmd /c echo scripts\\powershell\\check_iis_connections.ps1 -a "$ARG1$" "$ARG2$" "$ARG3$" "$ARG4$";
And restart the nrpe/nsclient service.
On the Nagios server change your command to this:
check_command check_nrpe!Check_iis_conn!TGCS014-N1!Default Web Site!5!10
And restart nagios with:
service nagios restart
Let me know if this works for you.
kwhogster
Post by kwhogster »
Well that made the service go green
but here is the output
Notifications for this service have been disabled
OK 06-05-2018 20:06:22 0d 0h 4m 21s 1/10 C:Program FilesNSClient++scriptspowershellcheck_iis_connections.ps1 :
Why does it format the command with out the slashes? is this the problem?
c:\Program Files\NSCLient++\scripts\powershell is the path
HTH
npolovenko
@kwhogster , Can you remove -a from this command:
Restart the nsclient and try one more time?
kwhogster
Post by kwhogster »
made the change restarted the nscp service same results here is the details
OK
(for 0d 20h 41m 19s)
Status Information: C:Program FilesNSClient++scriptspowershellcheck_iis_connections.ps1 :
Cannot process argument transformation on parameter 'warning_value'. Cannot
convert value "$" to type "System.Int32". Error: "Input string was not in a
correct format."
At line:1 char:66
+ ... ershell\\check_iis_connections.ps1 "$ARG1$" "$ARG2$" "$ARG3$" "$ARG4$ ...
+ CategoryInfo : InvalidData: (:) [check_iis_connections.ps1], Pa
rameterBindingArgumentTransformationException
+ FullyQualifiedErrorId : ParameterArgumentTransformationError,check_iis_c
onnections.ps1
Performance Data:
Current Attempt: 1/10 (HARD state)
Last Check Time: 06-06-2018 16:46:11
Check Type: ACTIVE
Check Latency / Duration: 0.000 / 0.707 seconds
Next Scheduled Check: 06-06-2018 17:46:11
Last State Change: 06-05-2018 20:06:22
Last Notification: N/A (notification 0)
Is This Service Flapping?
NO
(0.00% state change)
In Scheduled Downtime?
NO
Last Update: 06-06-2018 16:47:40 ( 0d 0h 0m 1s ago)
Active Checks:
ENABLED
Passive Checks:
ENABLED
Obsessing:
DISABLED
Notifications:
DISABLED
Event Handler:
ENABLED
Flap Detection:
ENABLED
Service Commands
Disable Active Checks Of This Service Disable active checks of this service
Re-schedule Next Service Check Re-schedule the next check of this service
Submit Passive Check Result For This Service Submit passive check result for this service
Stop Accepting Passive Checks For This Service Stop accepting passive checks for this service
Start Obsessing Over This Service Start obsessing over this service
Enable Notifications For This Service Enable notifications for this service
Send Custom Notification Send custom service notification
Schedule Downtime For This Service Schedule downtime for this service
Disable Event Handler For This Service Disable event handler for this service
Disable Flap Detection For This Service Disable flap detection for this service
Clear Flapping State For This Service Clear flapping state for this service
npolovenko
@kwhogster, I guess the goal is to find out how the plugin wants us to pass the parameters. Whether they should be separated by spaces, whether some flags should be before arguments and so on.
Can you run the plugin locally on the windows server using a PowerShell console with all the arguments and let us know if it works locally? If it does please copy the command and output. That way I will know how to adjust the nrpe command.
Can you also upload the plugin here? That way I can test it out.
kwhogster
Post by kwhogster »
From the server using powershell as administrator
Guess what I think might be it I then tried to run in power shell as the local user
PS C:\Users\sqladmin> cd "/program files/nsclient++/scripts/powershell"
Get-Counter : The \\tgcs014-n1\Web Service(default web site)\Current Connections performance counter path is not
valid.
At C:\program files\nsclient++\scripts\powershell\check_iis_connections.ps1:40 char:12
+ $counter = Get-Counter "\\$server\Web Service($website)\Current Conne ...
+ CategoryInfo : InvalidResult: (:) [Get-Counter], Exception
+ FullyQualifiedErrorId : CounterPathIsInvalid,Microsoft.PowerShell.Commands.GetCounterCommand
CONNECTIONS UNKNOWN default web site not found
Bare i mind of have four other powershell scripts that work in nagios on this same server
Wonder why this command does not work
Added the powershell plugin script as a txt file
check_iis_connections.txt
plug script
(1.62 KiB) Downloaded 339 times
