NagiosXI Sporadic Notifications
Re: NagiosXI Sporadic Notifications
Thanks for the profile. I took a look at the contact settings and they all looked correct.
The only thing I see is a log of stuck NSCA processes and they should be killed off by running the following as root.
pkill nsca
The phpmailer error "SMTP connect() failed" could be an issue with the Nagios server connecting to the SMTP server.
Could be a DNS issue or a loss in network connectivity, etc..
Can you check the logs on the SMTP server to see if there are any errors when the Nagios server is connecting to it?
blariv
Post by blariv »
found it was our internal relay getting clogged. thank you for the help and you can close this.
