Consulta Nagvis
Re: Consulta Nagvis
If it is started ..
Greetings
Greetings
Re: Consulta Nagvis
Huh?alex3105 wrote:If it is started ..
Greetings
Re: Consulta Nagvis
I attach the status of the service:
[root@localhost nagios]# service ndo2db status
Redirecting to /bin/systemctl status ndo2db.service
â— ndo2db.service - Nagios Data Out Daemon
Loaded: loaded (/usr/lib/systemd/system/ndo2db.service; enabled; vendor preset: disabled)
Active: active (running) since jue 2018-08-16 09:17:08 -05; 2h 42min ago
Docs: http://www.nagios.org/documentation
Process: 13520 ExecStopPost=/bin/rm -f /usr/local/nagios/var/ndo2db.pid (code=exited, status=0/SUCCESS)
Main PID: 13527 (ndo2db)
Tasks: 1
CGroup: /system.slice/ndo2db.service
└─13527 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg ...
ago 16 09:17:08 localhost.localdomain systemd[1]: Started Nagios Data Out Daemon.
ago 16 09:17:08 localhost.localdomain systemd[1]: Starting Nagios Data Out Daemon...
Tasks: 1
Re: Consulta Nagvis
Ok, that looks good. Now after modifying the nagios.cfg to add the ndo2db line, did you restart nagios?
After doing that what output do you get running
service nagios restartCode: Select all
echo 'select * from nagios.nagios_logentries;' | mysql -u ndoutils -p'ndoutils_password' nagiosRe: Consulta Nagvis
Add this line to the file nagios.cfg
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Restart the service, but I do not see records.
[root@localhost nagios]# service ndo2db statusRedirecting to /bin/systemctl status ndo2db.service
Active: active (running) since jue 2018-08-16 09:17:08 -05; 4h 49min ago
Tasks: 3
├─13244 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg ...
├─13249 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg ...
ago 16 13:33:28 localhost.localdomain ndo2db[13244]: Successfully connected to MySQ...e
ago 16 13:33:28 localhost.localdomain ndo2db[13249]: Successfully connected to MySQ...e
Hint: Some lines were ellipsized, use -l to show in full.
[root@localhost Documentos]# grep ndo /usr/local/nagios/etc/nagios.cfg
# Definitions for monitoring a Windows machine
#cfg_file=/usr/local/nagios/etc/objects/windows.cfg
# This option determines the "window" of time (in seconds) that
auto_rescheduling_window=180
Tasks: 3
Re: Consulta Nagvis
scottwilkerson wrote:
After doing that what output do you get runningCode: Select all
Re: Consulta Nagvis
Also I specifically asked if you restarted the nagios service, you showed output from the ndo2db servicescottwilkerson wrote:scottwilkerson wrote:
service nagios restartRe: Consulta Nagvis
The output of the command does not show records:
If I have restarted the nagios services and ndo2db. It seems strange to me ... I do not know what the problem may be.
Re: Consulta Nagvis
next I would want to see your
/usr/local/nagios/var/nagios.logRe: Consulta Nagvis
Dear Scott,
The file nagios.log could not pass it because it contains some sensitive information.
Greetings.
Greetings.
ndomod.cfg- (4.99 KiB) Downloaded 393 times
ndo2db.cfg- (6.02 KiB) Downloaded 387 times
