<?php
* NagVisObject.php - Abstract class of an object in NagVis with all necessary
* information which belong to the object handling in NagVis
* Copyright (c) 2004-2016 NagVis Project (Contact: [email protected])
* License:
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
* @author Lars Michelsen <[email protected]>
class NagVisObject {
protected $conf = array();
protected $object_id;
protected $x;
protected $y;
protected $z;
protected $icon;
protected $url;
protected $url_target;
protected $view_type;
protected $hover_menu;
protected $hover_childs_show;
protected $hover_childs_sort;
protected $hover_childs_order;
protected $hover_childs_limit;
protected $label_show;
protected static $sSortOrder = 'asc';
protected static $stateWeight = null;
private static $arrDenyKeys = null;
public function __construct() {}
* Get method for all options
* @return Value Value of the given option
public function get($option) {
return $this->{$option};
* Get method for x coordinate of the object
* @return Integer x coordinate on the map
public function getX() {
return $this->x;
* Get method for y coordinate of the object
* @return Integer y coordinate on the map
public function getY() {
return $this->y;
* Get method for z coordinate of the object
* @return Integer z coordinate on the map
public function getZ() {
return $this->z;
* Get method for type of the object
* @return String Type of the object
public function getType() {
return $this->type;
* PUBLIC getObjectId()
* Get method for the object id
* @return Integer Object ID
public function getObjectId() {
return $this->object_id;
* PUBLIC setObjectId()
* Set method for the object id
* @param Integer Object id to set for the object
public function setObjectId($id) {
$this->object_id = $id;
* Get method for the name of the object
* @return String Name of the object
public function getName() {
if($this->type == 'dyngroup' || $this->type == 'aggr') {
return $this->name;
} elseif ($this->type == 'service') {
return $this->host_name;
} else {
return $this->{$this->type.'_name'};
// Returns the display_name of an object, if available, otherwise
// the alias of an object, if available, otherwise the name
public function getDisplayName() {
if (isset($this->state[DISPLAY_NAME]) && $this->state[DISPLAY_NAME] != '')
return $this->state[DISPLAY_NAME];
elseif (isset($this->state[ALIAS]))
return $this->state[ALIAS];
else
return $this->getName();
* Get method for the hover template of the object
* @return String Hover template of the object
public function getHoverTemplate() {
return $this->hover_template;
* Set method for the object coords
* @return Array Array of the objects coords
public function setMapCoords($arrCoords) {
$this->setConfiguration($arrCoords);
* PUBLIC setConfiguration()
* Sets options of the object
public function setConfiguration($obj) {
foreach($obj AS $key => $val) {
$this->{$key} = $val;
* PUBLIC setObjectInformation()
* Sets extended information of the object
public function setObjectInformation($obj) {
* PUBLIC getObjectInformation()
* Gets all necessary information of the object as array
* @return Array Object configuration
public function getObjectInformation($bFetchChilds = true) {
global $CORE;
$arr = Array();
// When the childs don't need to be fetched this object is a child
// itselfs. So much less information are needed. Progress them here
// If someone wants more information in hover menu children, this is
// the place to change.
if(!$bFetchChilds)
return $this->fetchObjectAsChild();
// Need to remove some options which are not relevant
// FIXME: Would be much better to name the needed vars explicit
if(self::$arrDenyKeys == null)
self::$arrDenyKeys = Array(
'MAPCFG' => '', 'MAP' => '',
'conf' => '', 'services' => '', 'fetchedChildObjects' => '', 'childObjects' => '',
'parentObjects' => '', 'members' => '', 'objects' => '', 'linkedMaps' => '',
'isSummaryObject' => '', 'isView' => '', 'dateFormat' => '', 'arrDenyKeys' => '',
'aStateCounts' => '', 'iconDetails' => '', 'problem_msg' => '', 'isLoopingBacklink' => ''
foreach($this AS $key => $val)
if(!isset(self::$arrDenyKeys[$key]) && $val !== null)
$arr[$key] = $val;
if($this instanceof NagVisStatefulObject) {
$num_members = $this->getNumMembers();
if($num_members !== null)
$arr['num_members'] = $num_members;
// I want only "name" in js
if(!isset($CORE->statelessObjectTypes[$this->type])) {
$arr['name'] = $this->getName();
if($this->type == 'service') {
unset($arr['host_name']);
} else {
unset($arr[$this->type.'_name']);
if ($this->type == 'host' || $this->type == 'service') {
$obj_attrs = array(
'alias' => ALIAS,
'display_name' => DISPLAY_NAME,
'address' => ADDRESS,
'notes' => NOTES,
'check_command' => CHECK_COMMAND,
foreach ($obj_attrs AS $attr => $state_key) {
if (isset($this->state[$state_key]) && $this->state[$state_key] != '')
$arr[$attr] = $this->state[$state_key];
else
$arr[$attr] = '';
} elseif ($this->type == 'map'
|| $this->type == 'servicegroup'
|| $this->type == 'hostgroup'
|| $this->type == 'aggregation') {
$arr['alias'] = $this->state[ALIAS];
else
$arr['alias'] = '';
// Add the custom htmlcgi path for the object
$i = 0;
foreach($this->backend_id as $backend_id) {
if($i == 0) {
$arr['htmlcgi'] = cfg('backend_'.$backend_id, 'htmlcgi');
$arr['custom_1'] = cfg('backend_'.$backend_id, 'custom_1');
$arr['custom_2'] = cfg('backend_'.$backend_id, 'custom_2');
$arr['custom_3'] = cfg('backend_'.$backend_id, 'custom_3');
} else {
$arr['htmlcgi_'.$i] = cfg('backend_'.$backend_id, 'htmlcgi');
$arr['custom_1_'.$i] = cfg('backend_'.$backend_id, 'custom_1');
$arr['custom_2_'.$i] = cfg('backend_'.$backend_id, 'custom_2');
$arr['custom_3_'.$i] = cfg('backend_'.$backend_id, 'custom_3');
$i++;
// Little hack: Overwrite the options with correct state information
$arr = array_merge($arr, $this->getObjectStateInformations(false));
// If there are some members fetch the information for them
if(isset($arr['num_members']) && $arr['num_members'] > 0) {
$members = Array();
foreach($this->getSortedObjectMembers() AS $OBJ) {
$members[] = $OBJ->fetchObjectAsChild();
$arr['members'] = $members;
return $arr;
* PUBLIC getSortedObjectMembers()
* Gets an array of member objects
* @return Array Member object information
public function getSortedObjectMembers() {
$arr = Array();
$aTmpMembers = $this->getStateRelevantMembers();
// Set the sort order
self::$sSortOrder = $this->hover_childs_order;
// Sort the array of child objects by the sort option
switch($this->hover_childs_sort) {
case 's':
// Order by State
usort($aTmpMembers, Array("NagVisObject", "sortObjectsByState"));
break;
case 'k':
// Keep original order (as provided by backend)
break;
case 'a':
default:
// Order alhpabetical
usort($aTmpMembers, Array("NagVisObject", "sortObjectsAlphabetical"));
break;
// Count only once, not in loop header
$iNumObjects = count($aTmpMembers);
// Loop all child object until all looped or the child limit is reached
for($i = 0; $this->belowHoverChildsLimit($i) && $i < $iNumObjects; $i++) {
$arr[] = $aTmpMembers[$i];
return $arr;
* PUBLIC getObjectConfiguration()
* Gets the configuration of the object
public function getObjectConfiguration($abstract = true) {
// Some options have to be removed which are only for this object
$arr = $this->conf;
unset($arr['id']);
unset($arr['object_id']);
unset($arr['type']);
// Only remove these options when the configuration should be
// completely independent from this object
if($abstract == true) {
unset($arr['service_description']);
return $arr;
* PUBLIC parseJson()
* Parses the object in json format
* @return String JSON code of the object
public function parseJson() {
return $this->getObjectInformation();
* PUBLIC parseMapCfg()
* Parses the object in map configuration format
* @param Array Array of global map options
* @return String This object in map config format
public function parseMapCfg($globalOpts = Array()) {
$ret = 'define '.$this->type." {\n";
if($this->type === 'host')
$ret .= ' host_name='.$this->host_name."\n";
$ret .= ' object_id='.$this->object_id."\n";
foreach($this->getObjectConfiguration(false) AS $key => $val) {
// Only set options which are different to global option
if((!isset($globalOpts[$key]) || $globalOpts[$key] != $val) && $val != '') {
$ret .= ' '.$key.'='.$val."\n";
$ret .= "}\n\n";
return $ret;
* PUBLIC getUrl()
* Returns the url for the object link
public function getUrl() {
if(isset($this->url)) {
return $this->url;
} else {
return '';
# End public methods
* PROTECTED getUrlTarget()
* Returns the target frame for the object link
* @return String Target
protected function getUrlTarget() {
return $this->url_target;
* PRIVATE STATIC sortObjectsAlphabetical()
* Sorts both objects alphabetically by name
* @param OBJ First object to sort
* @param OBJ Second object to sort
private static function sortObjectsAlphabetical($OBJ1, $OBJ2) {
if($OBJ1->type == 'service') {
$name1 = strtolower($OBJ1->getName().$OBJ1->getServiceDescription());
} else {
$name1 = strtolower($OBJ1->getName());
if($OBJ2->type == 'service') {
$name2 = strtolower($OBJ2->getName().$OBJ2->getServiceDescription());
} else {
$name2 = strtolower($OBJ2->getName());
if ($name1 == $name2) {
return 0;
} elseif($name1 > $name2) {
// Sort depending on configured direction
if(self::$sSortOrder === 'asc') {
return +1;
} else {
return -1;
} else {
return -1;
} else {
return +1;
* PRIVATE STATIC sortObjectsByState()
* Sorts both by state of the object
private static function sortObjectsByState($OBJ1, $OBJ2) {
$state1 = $OBJ1->sum[STATE];
$subState1 = $OBJ1->getSubState(SUMMARY_STATE);
$state2 = $OBJ2->sum[STATE];
$subState2 = $OBJ2->getSubState(SUMMARY_STATE);
return NagVisObject::sortStatesByStateValues($state1, $subState1, $state2, $subState2, self::$sSortOrder);
* Helper to sort states independent of objects
public static function sortStatesByStateValues($state1, $subState1, $state2, $subState2, $sortOrder) {
global $_MAINCFG;
// Quit when nothing to compare
if($state1 === null || $state2 === null) {
return 0;
$stateWeight = $_MAINCFG->getStateWeight();
// Handle normal/ack/downtime states
if($stateWeight[$state1][$subState1] == $stateWeight[$state2][$subState2]) {
return 0;
} elseif($stateWeight[$state1][$subState1] < $stateWeight[$state2][$subState2]) {
if($sortOrder === 'asc') {
return +1;
} else {
return -1;
} else {
return -1;
} else {
return +1;
