workid
Posts: 34 Joined: Wed Oct 10, 2018 7:28 am
Post
by workid » Tue Oct 16, 2018 8:08 am
I have restarted but still have the same error:
could it be something to do with my commands.cfg file? when i try and verify that i get this error:
admin-it@GC-NAGIOS:/usr/local/nagios/etc/objects$ sudo /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/objects/commands.cfg
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Error in configuration file '/usr/local/nagios/etc/objects/commands.cfg' - Line 26 (NULL value)
Error processing main config file!
commands.cfg
(6.72 KiB) Downloaded 471 times
Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Tue Oct 16, 2018 8:44 am
workid wrote: I have restarted but still have the same error:
What error?
workid wrote: could it be something to do with my commands.cfg file? when i try and verify that i get this error:
You cannot verify individual .cfg files like this, only the nagios.cfg
workid
Post
by workid » Tue Oct 16, 2018 9:43 am
The error is:
(Return code of 127 is out of bounds. Check if plugin exists)
The plugin definitely exists:
admin-it@GC-NAGIOS:/usr/local/nagios/libexec$ ls
check_apt check_flexlm check_mailq check_overcr check_time
check_breeze check_ftp check_mrtg check_ping check_udp
check_by_ssh check_hpjd check_mrtgtraf check_pop check_ups
check_clamd check_http check_nagios check_procs check_uptime
check_cluster check_icmp check_ncpa.py check_real check_users
check_dhcp check_ide_smart check_nntp check_rpc check_wave
check_dig check_ifoperstatus check_nt check_sensors negate
check_disk check_ifstatus check_ntp check_smtp urlize
check_disk_smb check_imap check_ntp_peer check_snmp utils.pm
check_dns check_ircd check_ntp_time check_ssh utils.sh
check_dummy check_load check_nwstat check_swap
check_file_age check_log check_oracle check_tcp
I have the check command in the commands file:
command_name check_ncpa
command_line $USER1$/check_ncpa.py -H $HOSTADDRESS$ $ARG1$
Post
by scottwilkerson » Tue Oct 16, 2018 9:45 am
I asked this earlier but I do not see the plugin in the directory list you just showed
workid
Post
by workid » Tue Oct 16, 2018 10:01 am
sorry i don't understand... it is in the list i just posted above
workid
Post
by workid » Tue Oct 16, 2018 10:05 am
check_cluster check_icmp [color=#FF0000]check_ncpa.py[/color] check_real check_users
Post
by scottwilkerson » Tue Oct 16, 2018 10:09 am
Sorry I missed it.
Can you share the configuration definition for this host or service that is showing this error?
workid
Post
by workid » Tue Oct 16, 2018 10:17 am
is this in the ncpa.cfg file?
define host {
host_name NCPA 2 Host
address 172.17.136.147
check_command check_ncpa!-t 'Nagios_Token' -P 5693 -M system/agent_version
max_check_attempts 5
check_interval 5
retry_interval 1
check_period 24x7
contacts nagiosadmin
notification_interval 60
notification_period 24x7
notifications_enabled 1
register 1
service_description CPU Usage
check_command check_ncpa!-t 'Nagios_Token' -P 5693 -M cpu/percent -w 20 -c 40 -q 'aggregate=avg'
check_interval 5
retry_interval 1
check_period 24x7
register 1
service_description Memory Usage
check_command check_ncpa!-t 'Nagios_Token' -P 5693 -M memory/virtual -w 50 -c 80 -u G
check_interval 5
retry_interval 1
check_period 24x7
register 1
service_description Process Count
check_command check_ncpa!-t 'Nagios_Token' -P 5693 -M processes -w 150 -c 200
check_interval 5
retry_interval 1
check_period 24x7
register 1
Post
by scottwilkerson » Tue Oct 16, 2018 2:51 pm
What is the name of the host or service that is giving the
(Return code of 127 is out of bounds. Check if plugin exists) error?
also can you run the following so we can verify the plugin has the correct permissions
ls -al /usr/local/nagios/libexec/check_ncpa.py
workid
Post
by workid » Wed Oct 17, 2018 8:05 am
Host Name is the default : NCPA 2 Host
Services are:
CPU Usage
Memory Usage
Process Count
Her is the output from the code you asked me to run:
-rwxrwxr-x 1 nagios nagios 9982 Mar 8 2018 /usr/local/nagios/libexec/check_ncpa.py
