Waiting for configuration verification never ends.
suryakiran
Re: Waiting for configuration verification never ends.
I installed nagios with user root, Is that something i need to look-over as i am unable to restart with nagios user.
Log in as root and restart crond and nagios service. Let us know if this helped.
suryakiran
Its still the same. I have added couple of hosts and nothing is getting updated.
Let me know if you need to verify any logs.
Run the following commands as root user and show the output:
Log in as nagios user:
run the following commands, and show the output:
service nagios stop
service ndo2db restart
service nagios start
service crond restart
tail -50 /var/log/cronCode: Select all
su - nagiosCode: Select all
/usr/local/nagiosxi/scripts/reconfigure_nagios.shBe sure to check out our Knowledgebase for helpful articles and solutions!
suryakiran
Hi Good Morning,
Please check the below output.
Nov 7 09:35:01 njbbngeoxp3v CROND[23734]: (stdsmont) CMD (/opt/stdsmont/bin/heartbeat.pl > /dev /null 2>&1)
Nov 7 09:35:01 njbbngeoxp3v CROND[23736]: (stdsmont) CMD (/opt/stdsmont/agent/linux/proc_mon/ch eck_hungproc.pl > /dev/null 2>&1)
Nov 7 09:35:01 njbbngeoxp3v CROND[23735]: (stdsmont) CMD (/opt/stdsmont/bin/checkstdsmont.pl > /dev/null 2>&1)
Nov 7 09:35:01 njbbngeoxp3v crontab[23754]: (stdsmont) LIST (stdsmont)
Nov 7 09:35:01 njbbngeoxp3v crond[23717]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23721]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23720]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23717]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23716]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23719]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23721]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23720]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23725]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23724]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23718]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23719]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23722]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23716]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23723]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23725]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23724]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23722]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23718]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:01 njbbngeoxp3v crond[23723]: (nagios) FAILED to authorize user with PAM (Permissio n denied)
Nov 7 09:35:40 njbbngeoxp3v crond[30411]: (CRON) INFO (Shutting down)
Nov 7 09:35:40 njbbngeoxp3v crond[23964]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 46% if used.)
Nov 7 09:35:40 njbbngeoxp3v crond[23964]: (CRON) INFO (running with inotify support)
Nov 7 09:35:40 njbbngeoxp3v crond[23964]: (CRON) INFO (@reboot jobs will be run at computer's s tartup.)
Nov 7 09:35:59 njbbngeoxp3v crond[23964]: (CRON) INFO (Shutting down)
Nov 7 09:35:59 njbbngeoxp3v crond[23987]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 27% if used.)
Nov 7 09:35:59 njbbngeoxp3v crond[23987]: (CRON) INFO (running with inotify support)
Nov 7 09:35:59 njbbngeoxp3v crond[23987]: (CRON) INFO (@reboot jobs will be run at computer's s tartup.)
Nov 7 09:36:01 njbbngeoxp3v crond[23992]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:36:01 njbbngeoxp3v crond[23997]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:36:01 njbbngeoxp3v crond[23994]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:36:01 njbbngeoxp3v crond[23995]: (nagios) PAM ERROR (Permission denied)
Nov 7 09:36:01 njbbngeoxp3v crond[23997]: (nagios) FAILED to authorize user with PAM (Permissio
su - nagios
Last login: Tue Nov 6 17:19:08 EST 2018 on pts/3
-bash-4.2$ /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 13 services.
Checked 3 hosts.
Checked 12 host groups.
Checked 0 service groups.
Checked 2 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 3 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
-bash-4.2$ /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=4RW8B4BVjbWD' -O nagiosql.login--2018-11-07 09:37:07-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... 127.0.0.1
Connecting to localhost (localhost)|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: ‘nagiosql.login’
[ <=> ] 37,862 --.-K/s in 0.03s
2018-11-07 09:37:08 (1.28 MB/s) - ‘nagiosql.login’ saved [37862]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=4RW8B4BVjbWD' -O nagiosql.login--2018-11-07 09:37:08-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 37,862 --.-K/s in 0.02s
2018-11-07 09:37:09 (2.16 MB/s) - ‘nagiosql.login’ saved [37862]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2018-11-07 09:37:09-- http://localhost/nagiosxi/includes/components/ccm/
Saving to: ‘nagiosql.export.monitoring’
[ <=> ] 22,065 --.-K/s in 0.02s
2018-11-07 09:37:09 (873 KB/s) - ‘nagiosql.export.monitoring’ saved [22065]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.2.4
License: GPL
Checking objects...
Checked 3 hosts.
Checked 2 contacts.
Checked 3 hosts
Total Warnings: 0
Total Errors: 0
RET: 0
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to manage system services or units.
Authenticating as: root
Password:
polkit-agent-helper-1: pam_authenticate failed: Authentication failure
==== AUTHENTICATION FAILED ===
Failed to restart nagios.service: Access denied
See system logs and 'systemctl status nagios.service' for details.
su - nagios
Nagios Core 4.2.4
License: GPL
Checking objects...
Checked 3 hosts.
Checked 2 contacts.
Checked 3 hosts
Total Warnings: 0
Total Errors: 0
CMDLINE
LOGIN SUCCESSFUL!
Array
RESETTING PERMS
CMDLINE
LOGIN SUCCESSFUL!
CMDLINE:
OUTPUT:
Nagios Core 4.2.4
License: GPL
Checking objects...
Checked 3 hosts.
Checked 2 contacts.
Checked 3 hosts
Total Warnings: 0
Total Errors: 0
RET: 0
Password:
On the first page of this post, @npolovenko said:
Also, I asked you to run 5 commands as root, but you showed us only the tail of the cron log... Please, run the following commands as root and show the output:
and you replied:You have a polkit authentication agent running on this server, and its preventing the nagios user from having an access to the nagios service.
Now, we are seeing the same errors... Is polkit-agent still blocking nagios?I have done the changes, I am able to execute the below command...
If you want to use nagios to monitor your network infrastructure, you shouldn't be blocking it...==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Password:
service nagios stop
service crond restartBe sure to check out our Knowledgebase for helpful articles and solutions!
suryakiran
Hi ,
Sorry about the yesterday message. I thought i have done the changes but i dint. I am able to execute the command /usr/local/nagiosxi/scripts/reconfigure_nagios.sh ..... as a root user but with user nagios its giving error near polkit authentication.
We gave permissions for nagios to run cron and now the output is shown below, Couldn't see pam authentication error which i used to get before.
[root@njbbngeoxp3v nagiosxi]# /usr/sbin/service nagios stop
Stopping nagios (via systemctl): [ OK ]
[root@njbbngeoxp3v nagiosxi]# /usr/sbin/service ndo2db restart
Restarting ndo2db (via systemctl): [ OK ]
[root@njbbngeoxp3v nagiosxi]# /usr/sbin/service nagios start
Starting nagios (via systemctl): [ OK ]
[root@njbbngeoxp3v nagiosxi]# /usr/bin/systemctl restart crond.service
[root@njbbngeoxp3v nagiosxi]# tail -50 /var/log/cron
Nov 7 10:14:01 njbbngeoxp3v CROND[18856]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Nov 7 10:14:01 njbbngeoxp3v CROND[18857]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Nov 7 10:15:01 njbbngeoxp3v CROND[30294]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok)
Nov 7 10:15:02 njbbngeoxp3v CROND[30430]: (stdsmont) CMD (/opt/stdsmont/bin/checkstdsmont.pl > /dev/null 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30431]: (stdsmont) CMD (/opt/stdsmont/agent/linux/proc_mon/check_hungproc.pl > /dev/null 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30432]: (stdsmont) CMD (/opt/stdsmont/bin/heartbeat.pl > /dev/null 2>&1)
Nov 7 10:15:02 njbbngeoxp3v crontab[30458]: (stdsmont) LIST (stdsmont)
Nov 7 10:15:02 njbbngeoxp3v CROND[30471]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30472]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30470]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30474]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30475]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30476]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30477]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30481]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30482]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Nov 7 10:15:02 njbbngeoxp3v CROND[30483]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32159]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32160]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32161]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32162]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32163]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32164]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32165]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32166]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Nov 7 10:16:01 njbbngeoxp3v CROND[32168]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32717]: (stdsmont) CMD (/opt/stdsmont/agent/linux/filesystem/checkfs.pl > /dev/null 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32734]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32735]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32737]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32736]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32739]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32738]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32740]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32748]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Nov 7 10:17:01 njbbngeoxp3v CROND[32749]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[682]: (stdsmont) CMD (/opt/stdsmont/agent/linux/vmstat/checkvm.pl > /dev/null 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[693]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[696]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[697]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[698]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[701]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[702]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[705]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[706]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Nov 7 10:18:01 njbbngeoxp3v CROND[707]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Nov 7 10:18:03 njbbngeoxp3v crond[29021]: (CRON) INFO (Shutting down)
Nov 7 10:18:03 njbbngeoxp3v crond[851]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 95% if used.)
Nov 7 10:18:03 njbbngeoxp3v crond[851]: (CRON) INFO (running with inotify support)
Nov 7 10:18:03 njbbngeoxp3v crond[851]: (CRON) INFO (@reboot jobs will be run at computer's startup.)
It seems like cron jobs are running now - it's a good start!
However, the issue is only partially fixed.
Just to rule out suduers issues, can you post the /etc/sudoers file on the forum? We need to review it and make sure it hasn't been altered from the "default" in regards to nagios permissions.
You should be able to run reconfigure_nagios.sh as nagios user. I am not very familiar with polkit authentication policies/rules in order to help you with that. It's out of nagios support scope anyway. You will need to find a way to allow nagios user to be able to execute this command.I am able to execute the command /usr/local/nagiosxi/scripts/reconfigure_nagios.sh ..... as a root user but with user nagios its giving error near polkit authentication.
suryakiran
Please check the below ouput.
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
root ALL=(ALL) ALL
root ALL=(ALL) ALL
The sudoers looks correct. Make sure that you also have the following line:
You will still need to modify the polkit rules to allow nagios user to be able to execute reconfigure_nagios.sh.
Defaults:nagios !requirettyBe sure to check out our Knowledgebase for helpful articles and solutions!
