check_snmp return value with performance graph
Re: check_snmp return value with performance graph
The letter "c" on the output of the plugin lets the system know that the data is a counter.
There is a formula that counter data gets processed through and what you are seeing is rounding errors from that formula and is causing the graph to not display correctly.
To fix the issue, you have to create a template and a new command that will use the template.
The graph template that should fix the graphing issue with monitoring counters with the check_snmp plugin is attached to the post.
Here is how to install it.
In Core Config Manager
Create a copy of the check_snmp command and call it check_snmp_gauge
Edit the Command Name to check_snmp_gauge
       command_name                  		check_snmp_gauge
       command_line                  		$USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
Then edit the service check to use the check_snmp_gauge command like below
	host_name			xxx.xxx.xxx.xxx
	service_description		Test SNMP
	check_command			check_snmp_gauge! -P 2c -C public -o  1.3.6.1.2.1.4.31.1.1.35.1 -w 100 -c 110 -l test!!!!!!!
	max_check_attempts		5
	check_interval			5
	retry_interval			1
	check_period			xi_timeperiod_24x7
	notification_interval		60
	notification_period		xi_timeperiod_24x7
	contacts			nagiosadmin
	register			1
The graph template is called check_snmp_gauge.cfg and it needs to be uploaded to this folder in the XI system /usr/local/nagios/etc/pnp/check_commands/
/usr/local/nagios/etc/pnp/check_commands/check_snmp_gauge.cfg
Changed the permissions of the check_snmp_gauge.cfg file to the following
chown apache.nagios check_snmp_gauge.cfg
chmod 666 check_snmp_gauge.cfg
Delete the .rrd and .xml files for that service. They are in this folder under the hostname
/usr/local/nagios/share/perfdata/<HostName>/
After 15 minutes, the graph should be populated with the data.
bongbi
Post by bongbi »
Thanks. I take that attached file is the check_snmp_gauge.cfg file?
Yes, it is the cfg file, sorry about that too many similar files.
bongbi
Post by bongbi »
Thanks.
I have followed all instruction that you suggested and still facing same issue. Have I miss any step?
[root@nagiosxi check_commands]# pwd
[root@nagiosxi check_commands]# ls -al
total 16
drwxrwxr-x 2 apache nagios 4096 Feb  7 10:22 .
drwxrwxr-x 4 apache nagios 4096 Jan  7 15:45 ..
-rw-rw-r-- 1 apache nagios  755 Feb 19  2016 check_nwstat.cfg-sample
-rw-rw-rw- 1 apache nagios  749 Feb  7 10:22 check_snmp_gauge.cfg
[root@nagiosxi check_commands]# cat check_snmp_gauge.cfg
# Adapt the Template if check_command should not be the PNP Template
# check_command check_nwstat!LOAD5!80%!90%
# ________0__________|         |    |  |
# ________1____________________|    |  |
# ________2_________________________|  |
# ________3____________________________|
CUSTOM_TEMPLATE = 0,1
# Change the RRD Datatype based on the check_command Name.
# Defaults to GAUGE.
# Adjust the whole RRD Database
DATATYPE = GAUGE
# Adjust every single DS by using a List of Datatypes.
# DATATYPE = GAUGE,GAUGE,COUNTER,COUNTER
# Use the MIN value for newly created RRD Databases.
# This value defaults to 0
# USE_MIN_ON_CREATE = 1
# Use the MAX value for newly created RRD Databases.
# USE_MAX_ON_CREATE = 1
[root@nagiosxi check_commands]# cat /usr/local/nagios/etc/static/services.cfg
    host_name                nutanix-traf-ahv.internal
    service_description      clusterIops
    check_command            check_snmp_gauge! -o .1.3.6.1.4.1.41263.506.0 -P 3 --seclevel=authPriv --secname=nagios --authproto=sha --authpasswd='*' --privpasswd='*' --privproto=aes!!!!!!!
    check_interval           5
    retry_interval           1
    contact_groups           admins
    register                 1
Take a look in the /usr/local/nagios/var/perfdata.log file to see if the check is using the template.
You probably have to increase the log level to see that entry so edit this file.
/usr/local/nagios/etc/pnp/process_perfdata.cfg
Change the following entry to the example below.
LOG_LEVEL = 2
Restart nagios and npcd on the system and let the check run a few times and then check the log file to see if it is using the pnp template.
Also, make sure you delete the .xml and .rrd file for that service so it can be rebuilt.
bongbi
Post by bongbi »
Looks like it does not use template.
2019-02-11 09:33:38 [109320] [1] Found Performance Data for nutanix-traf-ahv.internal / clusterIops (iso.3.6.1.4.1.41263.506.0=146c)
2019-02-11 09:33:38 [109320] [2] Adapting Template using ARG 0,1
2019-02-11 09:33:38 [109320] [2] Adapting Template to check_snmp_gauge.php (added ARG0)
2019-02-11 09:33:38 [109320] [2] Adapting Template to check_snmp_gauge_-o .1.3.6.1.4.1.41263.506.0 -P 3 --seclevel=authPriv --secname=nagios --authproto=sha --authpasswd='5p1cpUKq' --privpasswd='5p1cpUKq' --privproto=aes.php (added ARG1)
2019-02-11 09:33:38 [109320] [2] Adapting Template to check_snmp_gauge_-o .1.3.6.1.4.1.41263.506.0 -P 3 --seclevel=authPriv --secname=nagios --authproto=sha --authpasswd='5p1cpUKq' --privpasswd='5p1cpUKq' --privproto=aes.php as defined in /usr/local/nagios/etc/pnp/check_commands/check_snmp_gauge.cfg
2019-02-11 09:33:38 [109320] [2] Adapting RRD Datatype to "GAUGE" as defined in /usr/local/nagios/etc/pnp/check_commands/check_snmp_gauge.cfg with key 0
2019-02-11 09:33:38 [109320] [2] Template is check_snmp_gauge_-o .1.3.6.1.4.1.41263.506.0 -P 3 --seclevel=authPriv --secname=nagios --authproto=sha --authpasswd='5p1cpUKq' --privpasswd='5p1cpUKq' --privproto=aes.php
2019-02-11 09:33:38 [109320] [2] No Custom Template found for check_snmp_gauge_-o_.1.3.6.1.4.1.41263.506.0_-P_3_--seclevel=authPriv_--secname=nagios_--authproto=sha_--authpasswd='5p1cpUKq'_--privpasswd='5p1cpUKq'_--privproto=aes (/usr/local/nagios/etc/pnp/check_commands/check_snmp_gauge_-o_.1.3.6.1.4.1.41263.506.0_-P_3_--seclevel=authPriv_--secname=nagios_--authproto=sha_--authpasswd='5p1cpUKq'_--privpasswd='5p1cpUKq'_--privproto=aes.cfg)
2019-02-11 09:33:38 [109320] [2] Template is check_snmp_gauge_-o_.1.3.6.1.4.1.41263.506.0_-P_3_--seclevel=authPriv_--secname=nagios_--authproto=sha_--authpasswd='5p1cpUKq'_--privpasswd='5p1cpUKq'_--privproto=aes.php
Edit the template
Change this line from
to
#CUSTOM_TEMPLATE = 0,1
Save it out.
Then run this to make a copy of it as a php file in the templates folder.
cp /usr/local/nagios/etc/pnp/check_commands/check_snmp_gauge.cfg /usr/local/nagios/share/pnp/templates/check_snmp_gauge.php
Delete the .xml and .rrd files and see if this resolves the issue.
bongbi
Post by bongbi »
Thanks! That fixed issue nicely.
Thanks for great support :)
I am glad it is working now. I'll close and lock the post as solved. Feel free to open a new post for any questions.
