This support forum board is for support questions relating to
Nagios Log Server , our solution for managing and monitoring critical log data.
Posts: 9191 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Thu May 02, 2019 4:46 pm
Edit the /usr/local/nagios/etc/nrpe/common.cfg file on the Centos7 server
Add a command like this
command[elastic]=/usr/local/nagios/libexec/check_services -p elasticsearch
Save the change and restart xinetd
Then run this command from the Nagios server
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -c elastic
If it fails, check the bottom of the /var/log/messages file on the logserver for any errors and post them here.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
Post
by tgriep » Thu May 02, 2019 4:55 pm
Great, getting progress.
What about this?
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -c check_services -a elastic
rferebee
Posts: 733 Joined: Wed Jul 11, 2018 11:37 am
Post
by rferebee » Thu May 02, 2019 4:59 pm
Yes, that worked too.
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Fri May 03, 2019 9:56 am
Is your issue resolved now or you have further questions?
rferebee
Post
by rferebee » Fri May 03, 2019 10:08 am
No, it's not resolved.
I shouldn't need to explicitly define every service I want to run a check against. We need to figure out why these checks are working properly on my original Log Servers, but not the new node I introduced.
Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Fri May 03, 2019 11:39 am
rferebee wrote: No, it's not resolved.
Please attach the /usr/local/nagios/etc/nrpe.cfg and /usr/local/nagios/etc/nrpe/common.cfg from your Log Server
rferebee
Post
by rferebee » Fri May 03, 2019 11:45 am
Please see attached. I uploaded both the working and not working versions of the files your requested.
Thank you.
Post
by scottwilkerson » Fri May 03, 2019 1:07 pm
the check_services commands are identical on these.
What is the error you are getting?
How are you running the command (can you give an example running the command from the CLI)
rferebee
Post
by rferebee » Fri May 03, 2019 1:27 pm
There error is: CHECK_NRPE: No output returned from daemon.
Here's the output from the CLI.
Bad server:
[rferebee@nagiosxi ~]$ sudo su -
root@nagiosxi> /usr/local/nagios/libexec/check_nrpe -2 -H 10.128.207.115 -t 30 -c check_services 'elasticsearch'
Good server:
root@nagiosxi> /usr/local/nagios/libexec/check_nrpe -2 -H 10.128.207.111 -c check_services -t 30 -a 'elasticsearch'
elasticsearch: 1
