Check drives size displays too much information
Re: Check drives size displays too much information
Please run this exact command and post the full output to the ticket.
/usr/local/nagios/libexec/check_wmi_plus.pl -H zzzzzzz -u xxxxxx -p yyyyy -m checkdrivesize -a 'D:' -w _FreeGB=10: -c _FreeGB=5:  "--debuglevel=4" -d
Frédéric GRANAT
Post by Frédéric GRANAT »
It returns the same output :
[[email protected] ~]# /usr/local/nagios/libexec/check_wmi_plus.pl -H xxxxxx -u xxxxxxx -p xxxxxx -m checkdrivesize -a 'C:|D:|E:|F:|G:|Q:|H:|I:|L:|M:|N:|R:' -w _FreeGB=10: -c _FreeGB=5: "--debuglevel=4" -d
Complex Format:_UsedSpace,#B,Used,, ,,
Please remove sensible data from your previous post (sorry I forgot to remove it)
You are not running the command like I asked, I only want you to run the check against the D: Drive only, not all of the drives on the system.
Frédéric GRANAT
Here it is :
[[email protected] ~]# /usr/local/nagios/libexec/check_wmi_plus.pl -H xxxxxxx -u xxxxxx -p xxxxxxx -m checkdrivesize -a 'D:' -w _FreeGB=10: -c _FreeGB=5: "--debuglevel=4" -d
Can you login to that windows server and get the properties of the D Drive and screen capture it and post it to the ticket so we can see it's details?
Run this as root on the Nagios server and post the output here.
/usr/local/nagios/libexec/check_wmi_plus.pl --version
Get all of the following files from the Nagios server and post them to the ticket.
/usr/local/nagios/libexec/check_wmi_plus.conf
/usr/local/nagios/libexec/check_wmi_plus.ini
Frédéric GRANAT
[root@nagiosxi ~]# /usr/local/nagios/libexec/check_wmi_plus.pl --version
Version: 1.64
I attached the files.
Thanks for the files. Just checking them to see is there were any changes to them that could effect the plugin.
Can you login to that windows server and get the properties of the D Drive, screen capture it and post it to the ticket so we can see it's details?
Frédéric GRANAT
Here are the properties of the D: drive
Nothing looks out of the ordinary so let's try running the plugin without any thresholds set to see if it works.
Run this command.
Another thing to look at is the permissions set on the drive.
If the user account you are using does not have access to the drive, it may cause that error.
Frédéric GRANAT
It's not a permission problem since the check on drive C: works well and I checked the permissions and it's correct
Last edited by Frédéric GRANAT on Thu Jun 20, 2019 5:00 am, edited 1 time in total.
