check_nrpe problems: Unable to read output and seteuid(0)
markgreene
Re: check_nrpe problems: Unable to read output and seteuid(0
Post by markgreene »
And I fixed it. Under "configure service", "monitoring" tab, I changed the command string to this:
check_nrpe!check_disk_all!5!10
removed the "-n" from /etc/sysconfig/nrpe on the remote host (added only because it was failing on SSL out of the gate), and restarted nrpe and forced the command.
So the short answer is the webUI NRPE wizard can't correctly construct complex commands, and I will verify the command strings under the "configure services" tab in the future.
mark
markgreene wrote:And I fixed it.
Glad to hear it is resolved!
Locking thread
