Dear Scott
Please find the command below
command_name snmp_load_15m
command_line $USER1$/check_snmp -o .1.3.6.1.4.1.2021.10.1.3.3 -H $HOSTADDRESS$ $ARG1$
unable to monitor windows server 2016 server using SNMP
sudakarman
sudakarman
Re: unable to monitor windows server 2016 server using SNMP
Dear Scott please help to resolve this issue
Checking objects...
Error: Service check command 'check_snmp_storage.pl!USEDDISKSPACE!-l c -w 80 -c 90' specified in service 'C: Drive Space' for host 'myserver' not defined anywhere!
Error: Service check command 'check_snmp_load.pl!CPULOAD!-l 5,80,90' specified in service 'CPU Load' for host 'myserver' not defined anywhere!
Error: Service check command 'check_snmp_mem.pl!MEMUSE!-w 80 -c 90' specified in service 'Memory Usage' for host 'myserver' not defined anywhere!
Error: Service check command 'check_uptime!UPTIME' specified in service 'Uptime' for host 'myserver' not defined anywhere!
Checked 13 services.
Checked 3 hosts.
Checked 2 host groups.
Checked 1 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 28 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 3 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 4
***> One or more problems was encountered while running the pre-flight check...
Checking objects...
Checked 3 hosts.
Checked 1 contacts.
Checked 3 hosts
Total Warnings: 0
Total Errors: 4
This looks like you don't have commands defined for these for check_commands you have defined
check_snmp_load.pl
check_snmp_mem.pl
check_uptime
Do you have these commands defined in your nagios configuration files?
check_snmp_load.pl
check_snmp_mem.pl
check_uptime
sudakarman
Dear Scott,
Thanks for your reply please find attachment
I can see the plugins exist, but you need to create command definitions for them in the nagios configuration files.
sudakarman
can you please share one command definition for memory monitor
http://nagios.manubulon.com/index_commands.html#memsudakarman wrote:can you please share one command definition for memory monitor
sudakarman
Dear Scott,
Thanks for your reply . Please find attached image getting community warning critical please suggest
Regards
sudakar
Regards
sudakar
Can you show the command definition you have for this along with the service definition?
