OK, one more thing... should I be concerned about this state?
"Could not authenticate. Invalid token given."
Unsuccessful Add of Instance
rocheryderm
Re: Unsuccessful Add of Instance
You might want to make sure your user has API access enabled
Admin ->User Management -> Edit
Permissions Tab
Select Yes
Save User (even if no change)
Click Username upper right, Click Generate New API Key
Then, log out and back in
Permissions Tab
Select Yes
rocheryderm
I'm logging in with an admin account (nagiosadmin).
I followed your instructions first just on server 1p. No effect. Then for fun, I did the same thing on the other 3 servers (2p, 3p, 4p).
No effect.
Any other ideas?
No effect.
Any other ideas?
Do you see the same if you select one of the other Instances from the drop-down?rocheryderm wrote:I'm logging in with an admin account (nagiosadmin).
No effect.
Any other ideas?
rocheryderm
Sorry for the late reply... yes.
Do these hosts know how to reach each other by hostname?rocheryderm wrote:Sorry for the late reply... yes.
cat /etc/hosts-
rocheryderm
Yes...
[root@rbbusnls1p ~]# cat /etc/hosts
127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4
::1 localhost localhost.localdomain localhost6 localhost6.localdomain6
151.120.113.51 rbbusnls1p
151.120.113.52 rbbusnls2p
151.120.113.53 rbbusnls3p
151.120.113.54 rbbusnls4p
I'm able to get those same icons if I restart the elasticsearch service but they go away as soon as I use F5 to refresh. Are you restarting the service to get these? Does refreshing the page help? I wouldn't be worried about these if you're restarting the service - the status of these services are stored in the elasticsearch database so you may see some 'odd' results during a restart.
