max_check_result_file_age
Re: max_check_result_file_age
That looks correct
sandeepatil
Post by sandeepatil »
Still not having issue.
Final confirmation will be on Monday
sandeepatil wrote:Still not having issue.
Sounds good, let us know
sandeepatil
Today we are facing same issue, with below permissions.
[nagios@server spool]$
[nagios@server spool]$ pwd
/opt/app/nagios/var/spool
[nagios@server spool]$ ls -l
total 93280
drwxrwxr-x 2 nagios nagios 95514624 Nov 19 07:05 checkresults
Please attach a copy of your nagios.cfg
sandeepatil
Please find attached nagios.cfg
nagios.cfg.txt
Nagjos config file
(5.24 KiB) Downloaded 471 times
Do these get picked up at all or does the file count only increase?
if you run this multiple time does it only go up?
ls /opt/app/nagios/var/spool/checkresults |wc -l
Do you see any errors in the nagios.log pertaining to the checkresults ?
What is the output of these commands?
ls -ld /opt/app/nagios/var/spool
ls -ld /opt/app
ls -ld /opt
sandeepatil
No error found in nagios.log
[nagios@server etc]$ ls /opt/app/nagios/var/spool/checkresults |wc -l
1458
2269
3512
3919
5088
5896
4637
3065
1970
3220
3691
4745
6167
5882
3548
3037
3941
4932
[nagios@server etc]$ ls -ld /opt/app/nagios/var/spool
drwxrwxr-x 3 nagios nagios 4096 Nov 19 08:01 /opt/app/nagios/var/spool
drwxrwxr-x 7 nagios nagios 4096 Nov 19 12:12 /opt/app/nagios/var/
drwxrwxr-x 13 nagios nagios 4096 Jul 3 12:01 /opt/app/nagios/
drwxr-xr-x 9 root root 4096 Dec 28 2018 /opt/app/
drwxr-xr-x 13 root root 4096 Mar 15 2019 /opt/
So it does appear they are being picked up by the nagios process
sandeepatil
I not getting what you are saying.
Please explain details,
