To try and clarify what I am asking is the max in and out numbers. How could they be that high for a 10/100 port.
mmestnik wrote:We stopped using Cacti and switched to PNP in F.
mmestnik wrote:It's still most likely a configuration issue. Can you verify the Performance data? If the graphs reflect this, then it's likely the problem is with the ??SNMP?? oids. One thing I just thought of was checking to make sure the Graph is not a *gauge.
* The number reported should be an ever increasing byte counter, you would then need to be graphing the change in this value over time and not the value it self.
mmestnik wrote:We do understand that this feature is something lacking from our product. Are you able to run these commands from the command line? SSH(ing) into the server can make testing these things much simpler also these commands all have a '--help' argument.
jladd wrote:Ok is there anything you could recommend me to check or re-install that might fix this? and if i were to install cacti and get that working If i buy a service plain will it still be supported.
jladd wrote:Is there any documentation you can show me so i can understand the configuration's of the plugins better. I started to look at them and play with them and noticed that i could clear up a few issues but im not experienced enough to be able to adjust all of the settings and what not?
jladd wrote:I am sorry i am still new to nagios and still learning linux can you tell me which commands and how to run them from console?
root@Bungle:/usr/local/nagios/libexec# ./check_http -I pluto.uk.nsynergy.com -a
123:123
HTTP OK - HTTP/1.1 302 Redirect - 0.690 second response time
|time=0.690064s;;;0.000000 size=457B;;;0
root@Bungle:/usr/local/nagios/libexec# ./check_http -H pluto.uk.nsynergy.com -a
123:123
HTTP OK - HTTP/1.1 302 Redirect - 6.493 second response time
|time=6.493219s;;;0.000000 size=467B;;;0
123:123
HTTP WARNING: HTTP/1.1 401 Unauthorized
With vvv root@Bungle:/usr/local/nagios/libexec# ./check_http -H
pluto.uk.nsynergy.com -a 123:123 -vvv
GET / HTTP/1.0
User-Agent: check_http/v2053 (nagios-plugins 1.4.13)
Connection: close
Host: pluto.uk.nsynergy.com
Authorization: Basic bmFnaW9zOjB2M3IyWTB1
