Setup Issues NRDS
mbowden
Re: Setup Issues NRDS
Post by mbowden »
Thank You
Ok, I believe this should fix this, on the XI server run:
chmod ug+rwx /usr/local/nrdp/plugins/
On the client run
/usr/local/nrdp/clients/nrds/nrds_updater.sh -f
Once this is set, adding additional clients shouldn't be a problem
mbowden
Post by mbowden »
[root@prod-bnrbat tmp]# /usr/local/nrdp/clients/nrds/nrds_updater.sh -f
Updated config to version 0.1
Updated 7 plugins
Looks like that might have fixed it!!
Excellent, this was a problem in the server component install script and should resolve any similar problems when you add this to other clients.
Thanks for you patience working through this, I think you'll find NRDS is pretty powerful now that the server is working right :lol:
