Installation of Nagios XI 5.7.4 fails on Rhel8
vtrac
Re: Installation of Nagios XI 5.7.4 fails on Rhel8
Post by vtrac »
Hi
Can you try force the install?
cpanm -f Class::Accessor
You can check all your installed module with the "instmodsh" command.
Exanple (select "l" to list all installed modules):
[root@vt-nagiosxi-62 .cpanm]# instmodsh
Available commands are:
   l            - List all installed modules
   m <module>   - Select a module
   q            - Quit the program
cmd? l
Please upload screenshot or status.
If you still having issue, we might try manually doing the make.
cd ~/.cpnm/latest-build/
look at the "build.log" and see what error you get.
Regards,
Vinh
portbris
Post by portbris »
We definitely don't have a proxy here. I have a sneaky suspicion that it might be some specific app we have blocked on the corp firewall that may be blocking it. We are investigating that now.
Yes, this was a clean VM install.
[root@vmnagios01 tmp]# cpanm -f Class::Accessor
-bash: cpanm: command not found
[root@vmnagios01 tmp]# instmodsh
cmd? l
Installed modules are:
Perl
cmd? q
[root@vmnagios01 tmp]# cd ~/.cpnm/latest-build/
-bash: cd: /root/.cpnm/latest-build/: No such file or directory
vtrac
Post by vtrac »
Looks like you only have just "Perl" module installed.
Once you have figured out the internet issue, please install CPAN, then cpanm.
yum install perl-CPAN
cpan App::cpanminus
Regards,
Vinh
portbris
Post by portbris »
Chased this down on the Cisco Firewall. Firesight was not impressed with that txt.gz file. It could not open the archive to inspect it, so it was blocking as potential malware.
Once this was fixed, I could run the cpan command and then the ./fullinstall worked.
Thanks for all your help.
portbris wrote:Chased this down on the Cisco Firewall. Firesight was not impressed with that txt.gz file. It could not open the archive to inspect it, so it was blocking as potential malware.
Great!
Locking thread
