Below is the output.
[root@localhost ~]# /usr/local/nagios/libexec/check_vmware_api.pl -H 10.105.0.28 -u root -p 'Po1ntnext!' -l cpu -s usage -w 80 -c 90
CHECK_VMWARE_API.PL CRITICAL - Server version unavailable at 'https://10.105.0.2 8:443/sdk/vimService.wsdl' at /usr/share/perl5/VMware/VICommon.pm line 734.
[root@localhost ~]#
Regards,
Venkata Reddy
Return code of 127 is out of bounds. Check if plugin exists
Re: Return code of 127 is out of bounds. Check if plugin exi
Hi Venkata,
Let's move this from the Forum to a support ticket.
Please create a ticket and reference this Forum Topic.
Thank you
Thank you
